3-Point Hitch warning NX series tractor owners
   / warning NX series tractor owners #11
There's a service bulletin about wiring under the hood something about them rubbing some were back the motor toward the dash they added some wire protection with clips to mine free warranty work check with your dealer when you have it in effects some nx models not sure which ones
Be nice if somebody could post the bulletin. Next time I get out to my tractor, I'll pop the hood and look at the wiring harness routing.
Cab wise, the loader hoses rub on the forward right lower edge of the cab.
   / warning NX series tractor owners #12
I don't know about the NX, but not long after I got it, my 2006 DK45 dropped a 3-PH lift arm off after losing a bale pin (ran a mower up onto a rear wheel and bent a bunch of stuff). All this stuff has bolts now, instead of pins...after all, how often do you need to remove a lift arm?
   / warning NX series tractor owners #13
So which NX do you have , cab , or no cab, hydro or shuttle ?
Nx 4510 cab hydro what I got from the dealer was nx series he did not specifically say what nx but mine was one I also said something about the hydraulic lines right front of the cab mine are all zip tied and long enough they do not rub one just barely touches he said they were going to let Kioti know one of the new ones they have on the lot were severely touching
   / warning NX series tractor owners #15
Ok thanks was just curios , I had checked my loader hoses after I bought mine and didn't have any hoses rubbing on mine either.
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
22ft Rollback Flatbed Body with Winch (A55852)
22ft Rollback...
Golf Cart (A55787)
Golf Cart (A55787)
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
INGERSOLL RAND G25 GENERATOR (A55745)
INGERSOLL RAND G25...
