warning buzzer/light for temp and oil
   / warning buzzer/light for temp and oil #11
between that and a flasher lamp.. should be easy to see.
murphy switchgages might be an option too?
soundguy
   / warning buzzer/light for temp and oil #12
Just remember this thing is going to go off every time you turn the key on to start it. Just keep that in mind before you hook the air horns up to it.
The system would need a starting time delay for oil pressure to avoid the air horn blast.:D
   / warning buzzer/light for temp and oil #13
or a simple bypass switch ...
ya,I thought of that................thanks.
   / warning buzzer/light for temp and oil #15
I will add my words… a low pressure sw for the oil and a low temp sw for the water can be added at the OEM location for each type of reading in the block.
Run a 12v feed line from the battery to the pressure/Temp Sw’s and to high output LEDs as stated.
Mount the LED in a small panel and put them in the BH Control Panel or mounted to it.
Yes they will light up when the key is turned on as stated and will go off as soon as the low pressure/temp sw’s value are reached.
Only special things needed would be the High output warning light(s) and the sw’s. wiring can be small ga (18-20) automotive wire (not the Home Depot kind - get it from a marine based electrical supply or something like that).
A warning buzzer is nice if the engine isn’t running at high rpms but if it is then you may not here the buzzer and the LED Lamps are not as annoying as the buzzer.
Great idea, I will add to my To-Do List.
Just my 2 cents and thanks for listening.
   / warning buzzer/light for temp and oil #16
if you wire from the battery, as your post states, the led's will run any time the key is off.. not good. better to wire from key-switched power instead.
soundguy
   / warning buzzer/light for temp and oil #17
soundguy
Your right missed that thks
Thanks for all the tips and replies.
after thinking it over,I am going to wait until my warranty is up,before I attempt this.
I will add my words a low pressure sw for the oil and a low temp sw for the water can be added at the OEM location for each type of reading in the block.
Run a 12v feed line from the battery to the pressure/Temp Sw痴 and to high output LEDs as stated.
Yes they will light up when the key is turned on as stated and will go off as soon as the low pressure/temp sw痴 value are reached.
Only special things needed would be the High output warning light(s) and the sw痴. wiring can be small ga (18-20) automotive wire (not the Home Depot kind - get it from a marine based electrical supply or something like that).
A warning buzzer is nice if the engine isn稚 running at high rpms but if it is then you may not here the buzzer and the LED Lamps are not as annoying as the buzzer.
If you end up doing this,could you keep us up to date on it?(pics and info)
   / warning buzzer/light for temp and oil #20
You've got my vote on this. :)
X2, 3 and 4
I think there is already a site for that stuff though, if you do it let us know; pics too please !
I do not have a shop I can get into at this time so it will take time/weather to get it together.
If we get warm weather it is something to consider.
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A55218)
2022 JCB 3TS-8T...
2019 Doosan LCV6W Towable LED Light Tower (A54811)
2019 Doosan LCV6W...
2019 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A52707)
2019 CATERPILLAR...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
1992 Ford L900 Cab Chassis with Low Milage Cummins (A55315)
1992 Ford L900 Cab...
