Warehouse racking for wood stacking?
/ Warehouse racking for wood stacking? #41
Ive switched to 1000L totes and find them better than using pallets and pallet racks for firewood.
Dont throw away the liners. Cut the tops about 4 inches down to make lids. Drill 3-4inch diameter holes in the bottom of the liner for air flow and drainage and remove the tote valves. Put the lids back on for keeping the rain out. Drill some 3/8 holes in the lids and liners an use zip ties to keep the wind from blowing the lids away.
You can now stack these totes 3 high outdoors and your wood stays dry. Grab one tote at a time with your tractor forks and bring it to the house when you need firewood. No more lean to痴 or wood shelters required.
Just toss your wood in the totes randomly and you never have to stack wood again. It痴 better to keep the wood random because you get better air flow and the wood stays dry better than neatly stacked wood.
Your biggest problems will be finding totes that didnt contain hazardous materials and the bases of the totes freezing onto the ground.
I agree with everything you said, and it sounds low effort with dry organized movable firewood as payoff.
I was going to say that biggest problem is finding totes (cheap), but once you avoid having to build a shed paying a few extra bucks for tote doesn't sound outrageous.
I am fairly invested into pallets and shed now, and shed holds enough firewood for current needs, but I do recommend others follow your advice.
/ Warehouse racking for wood stacking? #43
Mikester, I like your idea and I have access to several totes for $20 each. Could you post a couple pictures of your product?
Caterpillar V Series Lift Truck Service Manual (A63117)
Caterpillar V...
BUNDLE OF R19 INSOLATION & RD DUCT INSULATION (A64281)
BUNDLE OF R19...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
2006 JLG 2030ES 20ft Scissor Lift (A61572)
2006 JLG 2030ES...
UNUSED IRANCH IRTPL 10000 LB TWO-POST CAR LIFT (A64281)
UNUSED IRANCH...
