Grapple Wanting info on grapple buckets/thumbs
   / Wanting info on grapple buckets/thumbs #1
jmt1271
Platinum Member
MO
Kubota L2501
Guys, I am about to start the process of cleaning up after loggers who are cutting the timber on about 20 acres of my 35 acre place. It looks like a disaster area in the few acres they have done thus far. To do the job I have a 20" chain saw(Stihl 270) and my JD 3520. I have a 300 CX loader and it looks to me that a grapple bucket or even a hydraulic "thumb" would be worth its weight in gold for this job.
Can you guys offer advice on the utility of this attachment? Also, what is the most cost effective way to get into one? I have no additional hydraulics on the front, so this would have to be factored into the initial cost as well. What do I need to look at? also, on a tractor this size, is there sufficient power available to make this attachment worth the cost? Lastly, what is the approximate price range of each option?
Thanks.
   / Wanting info on grapple buckets/thumbs #2
Do a search here for "Millonzi", it sounds like it would be perfect for you!
HERE is thier webpage.
Do you have a rear remote?
No rear remote. Will check the site, thanks.
   / Wanting info on grapple buckets/thumbs #4
jmt1271 said:
No rear remote.
Well then, You could get the JD remote for your tractor, it cost's about $250 or so I think and run hoses from the rear up to the front of your FEL. Or you could get a diverter kit to add a remote to your FEL by splitting the curl circuit, that will cost about $550.00 or so...
I dont really understand the drawbacks of splitting the curl function. Please explain the pros and cons of the 2 options you mentioned.
I just called my nearest Deere dealer and he quoted me $411 for just the rear valve(!!!). He priced me a 60" grapple bucket(I think it is the "scrap grapple" on their website) this bucket was $1900 and apparently includes all lines and necessary extras. It is controlled by a switch on the fender. I dont like this as I want something with a new stick handle, so I wont have to remove my hand from the stick to control the grapple.
What I want to do is have Deere install the rear valve and necessary hydraulic lines to the bucket, then purchase a 4 prong grapple ,(prefferrably 2 independent grapples) and have it installed. Has anyone gone this route? What would be fair pricing for parts and labor? Is this the best route? The job is to clean up behind the timber cutters on about 20 acres.
   / Wanting info on grapple buckets/thumbs #6
I personally don't see any "drawbacks" of using a diverter setup. To me it's simple, with the button on the joystick pressed the grapple opens or closes, when the button is not pressed the bucket curls or dumps. Other opinions will vary, and there are many opinions!
You should do some searching here on TBN for HOURS of reading on this very subject. Key search words are "diverter", "WR Long", "grapple","4n1", "remote"
The dealer quoted the price on a 4n1 bucket, and you still will need the remote (front or rear) to make it work. And the price on the remote kit sounds high to me, but one thing is for sure-hydraulics are NOT CHEAP!
Having a dealer install is going to cost $$$, any reason you can't do it yourself?
The Millonzi grapple will cost about $1000.00 shipped to you, and will attach to your FEL with the JD Quick Attach setup you already have.
You need to do some searching! all the things your asking have been discussed HUNDREDS of times...
I am not sure what is involved with installing the grapple and associated parts, but I can probably do it myself, assuming it isnt too involved. Are there any special tools required? What is typically the most difficult part? How difficult is running the plumbing? Is there an online source for everything I need in one place?
As far as searching the forums, I have done so. But I like to ask questions that are specific to my situation. Also, a lot of times when you search you dont get the most current info. A lot of times new products or options have come to market.
Either way, I appreciate your input. Given all my questions, what do you think would be the best bang for the buck option? I will gladly try and install this stuff myself, if you guys think a guy of average to slightly better than average mechanical skills can do it properly.
   / Wanting info on grapple buckets/thumbs #8
I understand, but some people get tired of typing the same thing and answering the same questions over and over, so you may get limited responses.
Best bang for the buck IMHO is the Millonzi grapple, and either a diverter from WR Long or the rear kit from JD.
I am not sure what is involved with installing the grapple and associated parts, but I can probably do it myself, assuming it isn't too involved. Are there any special tools required? What is typically the most difficult part? How difficult is running the plumbing? Is there an online source for everything I need in one place?
"installing" the grapple is nothing, have you ever taken the bucket off your FEL? Pull two pins and uncurl and it pops right off!
Installing the diverter can be hard, but with the kit from WR Long it should go well...I built my own setup so I cannot comment on the 'Kit", but lots of people on TBN have been happy with there products.
   / Wanting info on grapple buckets/thumbs #9
I'm not positive, but doesn't the 3520 already have a 3rd SCV option ?
I believe the 3rd valve is there, it just needs tubing, connectors and a handle.
   / Wanting info on grapple buckets/thumbs #10
Hi jmt,
This is a pretty good thread to determine which kind of grapple you want or a bucket grapple or even a 4 in 1 bucket. After you decide which one suits your needs best, then I think figuring out the best way to plumb and operate it would be the next step.
Click here:
http://www.tractorbynet.com/forums/showthread.php?t=107635
2015 FREIGHTLINER M2 DAY CAB (A52141)
2015 FREIGHTLINER...
1997 JLG 40 Electric 40FT Articulating Boom Lift (A50322)
1997 JLG 40...
Club Car Electric Utility Cart (A51694)
Club Car Electric...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
