Wanted: Satoh Beaver Front Axle Shaft - Inner Yoke
   / Wanted: Satoh Beaver Front Axle Shaft - Inner Yoke #21
I've got a grey market Mitsubishi. These guys help keep it running: Valley Power They're located in Roanoke, VA.
   / Wanted: Satoh Beaver Front Axle Shaft - Inner Yoke #22
I have new & used parts. Parted out several S370d.
   / Wanted: Satoh Beaver Front Axle Shaft - Inner Yoke #23
Update??
Sorry for the slow follow-up. I was able to successfully customize the shaft to make it a square drive. I then milled a piece of 1018 steel for the hub part and adapted the yoke from a Weasler 300-6126. Everything worked out perfect. A lot of measuring, testing, grinding, milling, turning, etc. Worked great...
   / Wanted: Satoh Beaver Front Axle Shaft - Inner Yoke #25
That is nice work
   / Wanted: Satoh Beaver Front Axle Shaft - Inner Yoke #26
I am glad you got it fixed. Too bad it was so difficult.
   / Wanted: Satoh Beaver Front Axle Shaft - Inner Yoke #28
I have new & used S370d parts.Email me for details
Carolina 30-Ton Capacity Shop Press w/Pittsburg 20-Ton Jack, Model CP100, S/N 04020 (A59076)
Carolina 30-Ton...
Chemical Containers Tank (A57148)
Chemical...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
(2) FIBERGLASS LADDERS (A58374)
(2) FIBERGLASS...
SHOPBUILT HOG TRAILER SINGLE AXLE (A58374)
SHOPBUILT HOG...
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
