Wanted - 15 x 10 rims for Toolcat
   / Wanted - 15 x 10 rims for Toolcat #11
ruffdog,
Thanks for the links. I'll have to measure the offset and center bore size of my existing wheels. Thanks again.....
   / Wanted - 15 x 10 rims for Toolcat #13
Update needed, please.
Xfaxman,
I think I have previously read that you have the 29" tires on your TC. I was wondering if you could look to see how much clearance you have on the inside of the tires when it is in 4WS and the wheel has been turned all the way to one side. I checked mine with the 27" tires that are currently on it and am wondering if the 29" tires will fit. I think everything will be fine except when the steering is turned all the way to one side when it is in 4WS. It might just mean I can't turn the last little bit. I'll just have to decide if that is going to be a problem.
   / Wanted - 15 x 10 rims for Toolcat #15
If my 29" turfs can clear, xfax's R4 tires will have plenty of room.
ruffdog...what series TC do you have? Mine is a B-series which has the solid axles. I just don't know if the clearance is the same between the solid axle versions and the independent suspension versions.
   / Wanted - 15 x 10 rims for Toolcat #17
Mine is the G series. I can't answer your clearance question either.
   / Wanted - 15 x 10 rims for Toolcat #18
Mine is a G Series also, so big difference.
Some pictures of the F series:
453 Detroit Diesel Engine (A59213)
453 Detroit Diesel...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
2018 ISUZU NPR 16FT BOX TRUCK (A58017)
2018 ISUZU NPR...
Brush Cutter Mini Skid Steer Attachment (A56857)
Brush Cutter Mini...
TANK SEEDER (A58214)
1297 (A58374)
1297 (A58374)
