Want to move from 425 to 1430 or 1845
   / Want to move from 425 to 1430 or 1845
Cool - I'll check it out - Snows getting deep - now - Can't wait to go plow
I was thinking that with the 1430 - I would take a pipe out the
side and up - with quiet outboard muffler - I guess you would not be able to do that - but I don't know much about diesels
Also I don't want to retread old tires - i know you guys discussed this in another thread
I wonder why they used the air cooled unit (it is oil cooled though right?) I looked at the Deutz site - looks like they use those engines in mining - maybe thats why - Deutz does make the liquid ones as well
Great unit - how does the backhoe work for you
Can you really get down 8ft?
   / Want to move from 425 to 1430 or 1845 #54
As I have limited experience, I'm not the best source for backhoe feedback, but that said, here's what I have found:
The breakaway capacity is impressive....rocks, stumps offer little challange if the bucket curl leverage is applied right, but it has taken me a while to grasp technique. I have yet to dig down a full eight feet, but have no doubt it does that....you would however, essentially be digging below your feet, so my guess is it would require a lot of leaning forward to see what was up.
The limitation I find thus far is with the swing factor..(60 degree I think). If you are just digging a hole you plan to refill, it is not a problem, but if you want to move material, a lot of tractor re-positioning is required. My workaround is to load the mule and move to dump. A wider swing would not be a huge improvement, so I'm probably being overly critical. All in all I'm quite pleased to have it and have a list of projects lined up for it.
I know - I am not much of an operator myself and was having trouble digging - but my excavator friend jumped on it and he cranked the unit right up and was digging great with it
-So that tells me that ME the operator was the limitation
Since that time I did get better with it - Also the swing you
speak of - I think that is common to all backhoes - Some
probably go more than 60 - but my friend has one
backhoe and two excavators and he won't use the backhoe unless he has to - because of the stability, speed and the fact
that the excavator swings 360 degrees
But for me - the backhoe beats a hand shovel any day
   / Want to move from 425 to 1430 or 1845 #56
<font color=blue> the backhoe beats a hand shovel any day </font color=blue>
yeah, buddy....you got that right!
   / Want to move from 425 to 1430 or 1845 #57
<font color=red>Do you know anyone with a 1430?</font color=red>
Ed: Unfortunately, I don't know anyone with a 1430. I drove one at the factory, and a few months later went down to buy it. I came back with a piece of paper saying I owned an 1845 and a bunch of attachments. The 1430 is even a little more rackety than the 1845, since it is 2 cylinder rather than 3, but Pro Ears take care of that.
I would think that the 1430 would be great with the 60" deck. The 72 doesn't do as pretty cut, and would be a lot of load for the 30 hp.
But, as I wrote you in a post that apparently I didn't complete sending before disconnecting, I have a compromise to recommend. Instead of selling the 425 and buying a 1430, keep the 425 and supplement it with an 1850. /w3tcompact/icons/laugh.gif
Oh I almost fell off my chair laughing - I am screwball enough to do that - I spend a fair amount of time every day dreaming about attachments - their price sheet is addicting because it lists every single attachment the unit takes
Well I would like to make my decision without going back down there because it is not easy to get to (by plane)
but then again - I coud play around with the machines for a day
I just came in from plowing - that thing really is an animal -
I bent my plow believe it or not - I tried hammering it back with a sledge - it didn't move much - that is thick steel - I guess I will have to try heating it - I was going real fast pushing a huge load and didn't lift the blade fast enough to clear the curb - smacked my head on the roll bar as well - that will learn you quick not to make that mistake again (they don't have a spring on that plow)
   / Want to move from 425 to 1430 or 1845 #59
Ed,
How much snow did you guys get. How was the traction with the PT. I'm envious, we have only had just dustings of snow so far.
Duane
   / Want to move from 425 to 1430 or 1845 #60
SNOW
We here in No. VA. recieved 6"-8" of the Beautiful white stuff. I was out in the ATV plowing away for 2 hours. We have a very long driveway, but the little (280cc) ATV has a 48" blade on it. I tld the CFO that a bigger machine would work MUCH better, and give me more time to work on the dreaded "honey doo" list.
I also have that beach front property in the back that looks more like a swamp.
If you dont try to sell, it will never get sold!
Robert
2020 JOHN DEERE 245G LC EXCAVATOR (A52707)
2020 JOHN DEERE...
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
2014 Toyota Corolla Sedan (A55853)
2014 Toyota...
FAKE (A52472)
FAKE (A52472)
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
40' CONTAINER (A51244)
