Want to build a stump grinder....
   / Want to build a stump grinder.... #1
wadeschields
NYC and Pennsylvania
Ford 9N
So I am thinking about building a stump grinder to run off of the PTO on my Ford 9N. I have saved videos of people making a grinding wheel . Or I could buy a replacement wheel possibly. I was thinking of using a junk yard car front wheel assembly and making the grinding wheel to fit the lugs. Then I would need to make a mount for the assembly to attach to the three point hitch. Tractor Supply sells some of those that I might modify. Then find a drive shaft and make that fit. Build a shroud around the wheel for safety. Has anyone done this ? Or have a better idea. Or reason not to do this? I am sure there is a reason Stump grinders cost so much.... But what am I missing....
Thanks
Wade
PS. Also planning to make a boom arm. And looking to buy a post hole drill for the 9N
   / Want to build a stump grinder.... #2
How close does this fit your plans?
Bruce
I saw that video . I like what they did. But I was thinking even simpler design. No swing so no need to use hydraulics. And why change the direction of the blade? I was thinking just in line with the tractor. Pulling front and back as I go.
   / Want to build a stump grinder.... #4
That's not going to work very well, your 9N doesn't have a live PTO, so your blade is going to stop when ever you push the clutch in to go forward or backwards.
Good point . Guess the video guy's idea is better. So how does the hydraulics hook up? I think I saw a video showing a different plate on the tractor with a hook up somewhere?
2014 Dodge 5500 4X4 Bucket Truck (A53472)
2014 Dodge 5500...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2018 New Holland Workmaster 60 4x4 Tractor with Loader (A51573)
2018 New Holland...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
