Want to build a stump grinder....
   / Want to build a stump grinder.... #1
wadeschields
NYC and Pennsylvania
Ford 9N
So I am thinking about building a stump grinder to run off of the PTO on my Ford 9N. I have saved videos of people making a grinding wheel . Or I could buy a replacement wheel possibly. I was thinking of using a junk yard car front wheel assembly and making the grinding wheel to fit the lugs. Then I would need to make a mount for the assembly to attach to the three point hitch. Tractor Supply sells some of those that I might modify. Then find a drive shaft and make that fit. Build a shroud around the wheel for safety. Has anyone done this ? Or have a better idea. Or reason not to do this? I am sure there is a reason Stump grinders cost so much.... But what am I missing....
Wade
PS. Also planning to make a boom arm. And looking to buy a post hole drill for the 9N
   / Want to build a stump grinder.... #2
How close does this fit your plans?
Bruce
I saw that video . I like what they did. But I was thinking even simpler design. No swing so no need to use hydraulics. And why change the direction of the blade? I was thinking just in line with the tractor. Pulling front and back as I go.
   / Want to build a stump grinder.... #4
That's not going to work very well, your 9N doesn't have a live PTO, so your blade is going to stop when ever you push the clutch in to go forward or backwards.
Good point . Guess the video guy's idea is better. So how does the hydraulics hook up? I think I saw a video showing a different plate on the tractor with a hook up somewhere?
2012 DODGE DURANGO SUV (A52576)
2012 DODGE DURANGO...
2015 Mack GU813 Mixer Concrete Truck, VIN # 1M2AX13C0FM028499 (A51572)
2015 Mack GU813...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A52472)
2018 WACKER NEUSON...
28013 (A50322)
28013 (A50322)
2017 Currahee Trailers Trailer, VIN # 4TEFS1826H1034878 (A51572)
2017 Currahee...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
