3-Point Hitch want to add tilt control to 3 point hitch 0n Kubota L3400
   / want to add tilt control to 3 point hitch 0n Kubota L3400 #1
brosenbaum
houston texas
L3400
I am wanting to add tilt control to 3 point hitch on L 3400; definitely handy for many attachments, especially cutting long drainage swales - plan to moung my laser level sensor in blade to monitor/control grade along 700 ft cut.
Looking for suggested cylinder size, control valve, mounting locations, etc, plus suggestions on where to purchase parts.
Will post picts when operational -that is being oprimistic bacause I know I will be getting great pratical ideas from the orange tractor team.
   / want to add tilt control to 3 point hitch 0n Kubota L3400 #3
For your sidelink you will need a rear remote, one with float works nice for a sidelink.
   / want to add tilt control to 3 point hitch 0n Kubota L3400 #4
Your L3400 is probably similar to my L3010. I got my top and tilt cylinders from Brian MtnViewRanch. Sounds like you are planning to build a hydraulic control system with a lazer input ?? Pretty interesting. Keep us informed.
   / want to add tilt control to 3 point hitch 0n Kubota L3400 #5
If you are a good fabricator, you can get a 6" stroke cylinder to work, but it is tight. Otherwise just use a 4" stroke unit. Typically for your size tractor I would use a 2" dia hydraulic. I also highly recommend a flow restrictor, makes the adjustments much much easier.
As far as the rear remote, the OEM unit would be the cleanest route, but a bit more costly. If you go aftermarket, might as well go with at least 2 if not 3 sets. Depending on how you do it, cost can vary quite a bit.
What implement are you going to use for the grading? I ask because if you will be using a box blade or land plane grading scraper, then I highly recommend that you get a hydraulic top link also. So as long as you are going to be doing some plumbing, might as well put in 2 or 3 like I suggested.
By the way, a complete Top and Tilt kit from me, cylinders, hoses with QD ends and flow restrictors would be $530 + shipping costs. I can get you a valve set also if you want to go the aftermarket route.
Good luck. ;)
   / want to add tilt control to 3 point hitch 0n Kubota L3400 #6
Brian, could you ad a picture to your post for what you quoted please, and the valve set, 4 vs 6" ram. Thanks
   / want to add tilt control to 3 point hitch 0n Kubota L3400 #7
Go to the Fit Rite website shown in my signature to see a complete "TnT" kit. I do not have any pictures showing the actual difference between the 6" & 4" strokes. Pretty much look the same, just pin hole location is different and I have to give up some of the clearances that I prefer to have and are built into the OEM links. Here is a link to the company that I get my valves from. You can buy direct if you want, just won't get as good of a price as I will give you.
http://www.hydraulicstore.com/products/hydraulic/bucher_hds11_manual_valves.html
Let me know if you need anything else. ;)
2017 Chevrolet Silverado (A53317)
2017 Chevrolet...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2022 RAM 2500 HEAVY DUTY (A58214)
2022 RAM 2500...
2022 New Holland C332 (A53317)
2022 New Holland...
2019 Caterpillar CB24B (A53317)
2019 Caterpillar...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
