Chipper Wallenstein Chipper
   / Wallenstein Chipper #21
dooger54 said:
dbk123 - I'm surprised you are able to run the BX62 on your tractor. My conversations with both the people at Woodward Crossings and Wallenstein told me that the 62 requires a minimum of 50hp to run effectively. I have a New Holland TC35 and was told I need to stick with the BX42.
Anyone else have comments on this?
Believe the people you've talked to...:D
I run my BX62 on a JD2640...which is 70hp
   / Wallenstein Chipper #22
OK, I'll chime in.
I bought my PTO chipper four years ago. I did alot of reserach and even tracked down a few people who let me come over the try out their chipper.
I settled on a Salsco PTO 627. Here is a link to an informational page:
http://www.salsco.com/products/627, LIT, 2000 WEB.pdf
I absolutely love it. Once it grabs ahold of whatever I shove into it, I stand back and let it go. Hydraulic is nice, but adds considerable expense. It all depends on how much you use it and what you will be sending through it.
   / Wallenstein Chipper #24
We have the bx62 and run in on our JD 4310 which only has 28.5 hp at the pto. Haven't had a problem with it yet, stalled it out a couple times by putting 6" hardwood through it, but no problems.
   / Wallenstein Chipper #25
Kurt-- I don't know if you are still following this thread, but R & S in Torrington sells the Wallenstein chippers. I was there yesterday.
   / Wallenstein Chipper #26
The BX62's larger flywheel is nice isn't it?...:) I would guess you are primarily running smaller stuff thru your 62, correct?
Case Axial-Flow Combine Wheels NO RESERVE (A55315)
Case Axial-Flow...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2014 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2014 Ford F-150...
66in Bucket Skid Steer Attachment (A55851)
66in Bucket Skid...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
