Chipper Wallenstein Chipper
/ Wallenstein Chipper #21
dooger54 said:
dbk123 - I'm surprised you are able to run the BX62 on your tractor. My conversations with both the people at Woodward Crossings and Wallenstein told me that the 62 requires a minimum of 50hp to run effectively. I have a New Holland TC35 and was told I need to stick with the BX42.
Anyone else have comments on this?
Believe the people you've talked to...:D
I run my BX62 on a JD2640...which is 70hp
/ Wallenstein Chipper #22
OK, I'll chime in.
I bought my PTO chipper four years ago. I did alot of reserach and even tracked down a few people who let me come over the try out their chipper.
I settled on a Salsco PTO 627. Here is a link to an informational page:
http://www.salsco.com/products/627, LIT, 2000 WEB.pdf
I absolutely love it. Once it grabs ahold of whatever I shove into it, I stand back and let it go. Hydraulic is nice, but adds considerable expense. It all depends on how much you use it and what you will be sending through it.
/ Wallenstein Chipper #24
We have the bx62 and run in on our JD 4310 which only has 28.5 hp at the pto. Haven't had a problem with it yet, stalled it out a couple times by putting 6" hardwood through it, but no problems.
/ Wallenstein Chipper #25
Kurt-- I don't know if you are still following this thread, but R & S in Torrington sells the Wallenstein chippers. I was there yesterday.
/ Wallenstein Chipper #26
The BX62's larger flywheel is nice isn't it?...:) I would guess you are primarily running smaller stuff thru your 62, correct?
2018 New Holland C227 Compact Track Loader (A63118)
2018 New Holland...
Four (4) Michelin 520/70R38 Mega Bib Floater Tires (A63116)
Four (4) Michelin...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A59911)
2020 FREIGHTLINER...
2016 John Deere 1795 Planter (A63109)
2016 John Deere...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
24in excavator tooth bucket (A61307)
24in excavator...
