Chipper wallenstein bx62 chipper
/ wallenstein bx62 chipper #1
farmerjim
new london county,ct
jd h, jd 50, jd2010,jd 790,case530hoe
i've got a line on a bx62 chipper and was wondering if its too big for my jd790? i plan to put nothing bigger than say 4in material through it.
/ wallenstein bx62 chipper #2
Wallenstein Units...................................42.................................62
Drive System Direct drive, PTO w/ shearbold Direct drive, PTO w/ shearbold
HP requirements for max. cap. 35-40............................ 60-70
Chipper Capacity 4" Dia. (max. 10" slab) 6" Dia. (max. 12" slab)
Chipper Housing Opening 4" x 10" 6ス" x 12"
Rotor Size 25" 30"
Number of Rotor Knives 4 4
Knife Type Hardened tool steel Hardened tool steel
Rotor Weight......................................74 lbs............................... 197 lbs.
Feeding System Feed..........................Self Feed......................... Self Feed
Mounting System 3 Point Hitch 3 Point Hitch
Dimensions (Hopper Folded) 40"L x 42"W x 60"H 50"L x 52"W x 74"H
Hopper Opening 20" x 20" 25" x 25"
Discharge Hood Rotation 360ー 360ー
Discharge Hood Height 60" 74"
Rated RPM 540-1000 540-1000
Weight..........................................425 lbs......................770 lbs.
/ wallenstein bx62 chipper #3
I've run my BX62 on as little as 18hp and 5 gpm......... you would have no trouble running one on your 790 as long as you aren't trying to use it to capacity. For me....... anything from 3-4 inches up is firewood and doesn't get chipped.
/ wallenstein bx62 chipper #4
I've the equivalent Salsco unit and I always sharpen,lap, and hone (as I would a bench chisel) after I use the machine. I find this makes a huge difference in the tractor/chipper ability. I am able to clean up the edges with the blades installed but a major ding would require removal, don't know about the wallensteins.
Gotta keep very sharp blades.
Good luck.
Dale
/ wallenstein bx62 chipper #5
In other words...you are pampering your BX62...:D
I'll remember that when you get around to selling it some day...I'll be the first one in line bidding for it...:rolleyes:
/ wallenstein bx62 chipper #6
I was looking for a used BX42 when i came across this one locally. Guy i bought it from bought it new and supposedly only used it to clear his house lot. It was more than i really needed, but......................
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2016 Chevrolet 2500 HD 4WD (A63118)
2016 Chevrolet...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
2005 FORD E-350 S/A MOBILE CONCEPTS CUSTOM CONVERSION (A59910)
2005 FORD E-350...
Great Dane Van Trailer (A63118)
Great Dane Van...
