Chipper wallenstein bx62 chipper
/ wallenstein bx62 chipper #1
farmerjim
new london county,ct
jd h, jd 50, jd2010,jd 790,case530hoe
i've got a line on a bx62 chipper and was wondering if its too big for my jd790? i plan to put nothing bigger than say 4in material through it.
/ wallenstein bx62 chipper #2
Wallenstein Units...................................42.................................62
Drive System Direct drive, PTO w/ shearbold Direct drive, PTO w/ shearbold
HP requirements for max. cap. 35-40............................ 60-70
Chipper Capacity 4" Dia. (max. 10" slab) 6" Dia. (max. 12" slab)
Chipper Housing Opening 4" x 10" 6ス" x 12"
Rotor Size 25" 30"
Number of Rotor Knives 4 4
Knife Type Hardened tool steel Hardened tool steel
Rotor Weight......................................74 lbs............................... 197 lbs.
Feeding System Feed..........................Self Feed......................... Self Feed
Mounting System 3 Point Hitch 3 Point Hitch
Dimensions (Hopper Folded) 40"L x 42"W x 60"H 50"L x 52"W x 74"H
Hopper Opening 20" x 20" 25" x 25"
Discharge Hood Rotation 360ー 360ー
Discharge Hood Height 60" 74"
Rated RPM 540-1000 540-1000
Weight..........................................425 lbs......................770 lbs.
/ wallenstein bx62 chipper #3
I've run my BX62 on as little as 18hp and 5 gpm......... you would have no trouble running one on your 790 as long as you aren't trying to use it to capacity. For me....... anything from 3-4 inches up is firewood and doesn't get chipped.
/ wallenstein bx62 chipper #4
I've the equivalent Salsco unit and I always sharpen,lap, and hone (as I would a bench chisel) after I use the machine. I find this makes a huge difference in the tractor/chipper ability. I am able to clean up the edges with the blades installed but a major ding would require removal, don't know about the wallensteins.
Gotta keep very sharp blades.
Good luck.
Dale
/ wallenstein bx62 chipper #5
In other words...you are pampering your BX62...:D
I'll remember that when you get around to selling it some day...I'll be the first one in line bidding for it...:rolleyes:
/ wallenstein bx62 chipper #6
I was looking for a used BX42 when i came across this one locally. Guy i bought it from bought it new and supposedly only used it to clear his house lot. It was more than i really needed, but......................
20ft. Shipping Container (A64047)
20ft. Shipping...
John Deere 6125R Tractor (A64047)
John Deere 6125R...
John Deere 5045E for sale
John Deere 5045E...
PALLET OF LONG WIRES FOR UPRIGHT TOBACCO BALER (A63745)
PALLET OF LONG...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
