Walkway/path suggestions?
/ Walkway/path suggestions? #1
snal
NC
Kubota BX24
I've cut a terrace/path across my front bank, and I'm trying to decide what to use as a base for the path. I'd love to use brick pavers, but this would blow my budget, and really wouldn't "fit" since I'm trying to keep a rustic look.
I'll be using rocks that I've collected from my property to stablize the bank on the upper side, so I'm considering some sort of gravel base for the path, but I am open to alternatives. It'd be interesting to hear any suggestions.
Hopefully there are pics listed below.
/ Walkway/path suggestions? #2
Pea gravel? Maybe a layer of mulch over the top lightly?
Yeah...that'd work. I do plan to mulch the bank above and somewhat below the path. Figured I'd lay down some fabric on the path, possibly some sort of edging, then some sort of gravel or other material.
/ Walkway/path suggestions? #4
pea gravel won't pack well however ... I'd use what is called "granite gravel" around here. it's smaller than pea and packs really well. I used it for an underlayment for some flat stone I used for a walk at the house in town. I put it down, spread it out, then before I could stomp it - it rained and the darn stuff packed itself. hate it when that happens..... but it convinced me it's what I'll use in the country for walkways.
/ Walkway/path suggestions? #5
We used pea gravel under our deck. I can tell you from 1st hand experience that you don't want to walk on the stuff. It's like marbles when you put your weight on it.
/ Walkway/path suggestions? #6
From the pictures you appear to have a lot of elevation. Unless you plan on putting in some sort of drainage system you will have a lot of erosion. Perhaps some sort of wood walkway, even rustic uncut logs or trees.
My dad used to build roads on lots of hills and he always sloped the road slightly to the downhill side to ecourage the water to sheet off instead of becoming a small river and really eroding the road base.
Good luck. I love projects like this. Please keep us posted with pictures. :)
/ Walkway/path suggestions? #7
I have a gravel drive and road top the shop and shed. I made a place to run a circle around some cedar trees beside the shop and I put mulch down to cover the mud. I drive the tractor and golfcart on it constantly and all I have had to do is spray it with round-up a couple times a year. If it wears to thin, 5 yards of mulch cost me 15.00. Maybe it would work for you. HTH, later, Nat
Rick, I don't get very much erosion on this bank, least not in 6 years. I do plan to put various plants above and below the path, and I have sloped the path back towards the upper side, and it also has a slight crown to it along the length of the path. The pics make it look steeper than it actually is, and the path has been groomed quite a bit since those pics were taken.
We've had a few downpours since those pics, and the only place that I've seen any erosion is where my downspout drain lines empty on the upper bank, those lines will bo routed to an 18" culvert down below.
/ Walkway/path suggestions? #9
Cool, snal. Sounds like you've got it going in the right direction. Keep the updated pictures coming.
/ Walkway/path suggestions? #10
Hi snal,
wood chips or pine straw would be pretty rustic & cheap... especially if you produce your own... just would need to add more as they thin out on you
Well...the heatwave as made progess sloooow! Can't even let the tractor do most of the work without bathing in sweat! I decided to use railroad ties for the retaining wall instead of rock, since I couldn't locate enough "free" rock. I laid the first course by hand, then I was able to use the BH and thumb to set the second and third courses fairly close (I'm getting better at this BH stuph!).
Still a ways to go...but I'm getting there!
/ Walkway/path suggestions? #12
I went to a class on trail building in the State Park. Most of it was PC BS, but they did have a few good ideas.
One was to use rebar to anchor your edges in place. They drilled a half inch hole through the log and pounded a half inch length of rebar through it, and into the ground. Three or four of these, depending on how long the log was, would anchor it in place very nicely.
They also talked about ways to finish the trail.
Blacktop is the prefered material, but it's expensive and dificult to install further out in the woods.
Mostly they use mulch. It's easy, cheap and very effective.
Eddie
Thanks Eddie...I used 5/8" rebar 2' long to anchor the base ties, then 12' long pieces to anchor the next row to the previous row. This has worked well where I've used the RR ties elsewhere. I found a couple of truckloads of free mulch about a half mile from my place...so I suppose that's what I'll be using for the path.
Thanks for the help!
/ Walkway/path suggestions? #14
Seeing as you have a hoe I'd suggest some deadmen for lateral support. :)
2018 MACK PINNACLE (A67714)
2018 MACK PINNACLE...
Set of 2 Unused ST205/75R15 Radial Trailer Tires (A66734)
Set of 2 Unused...
2018 GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
2018 GENERAC...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
