Walk behind brush mowers
/ Walk behind brush mowers #1
NIXON
Veteran Member
West Sunbury ,Pa.
L3130 hst
I'm looking for something that I can use to get into areas too tight for a tractor and brush hog . I'd like something that will cut saplings in the range of 1.5 to 2 inches . About the only folks that still make them are DR and Snapper . If any of You have experience with either of these makes ,I'd appreciate your comments on them . And, If anyone is aware of any other maker of this type of machine ,Your input would be most welcomed as well.
Thanks , John
/ Walk behind brush mowers #3
Northern Tool offers 'Swisher' brand in the type of mower you are referring to.
I have read where some of these mowers can be real beasts to manuver.
There are also some previous posts on this forum - use the search function to locate these.
/ Walk behind brush mowers #4
Mornin John,
My neighbor up the road about a 1/2 mile has a 15hp DR field walk behind. He has had it a few years and seems happy with it. He owns about 150 acres but he has some steep hillside up behind his house and uses it on those steep grades were tractor operation would be impossible. The higher HP units have anoil pump enabling use on steep grades. If you have any more specific questions I would be happy to ask him.
scotty
/ Walk behind brush mowers #5
I've had the DR 17HP Brush mower for about 1.5 years. I've been pleased with it so far. Iv'e got about 20 hours on it reclaiming an overgrown field. It's a tank and will chew up anything it can push over. The 2.5" capacity stated by DR is not an exaggeration.
Thanks for the responses. I've contacted the various makers you all have listed . And even used the search feature here /forums/images/graemlins/blush.gif
(somehow I tend to forget about it,and need a reminder )
So far the 17 hp DR seems to be a good bet as far as power and durability. John
/ Walk behind brush mowers #7
NIXON,
I own the DR Field & Brush Mower w/17hp Kawasaki engine and highly recommend it. I have the 30" brush deck, 42" finish mowing deck, and the generator attachment. I believe DR also offers that unit with an 18hp Honda engine for more money and by special order.
There are two good previous threads in this forum in recent months. In them I compared the DR models to the walk-behind brush cutter competition from Simplicity/Snapper/Ferris (same ownership & manufacturing) and from Billy Goat. I concluded that the 17hp+ DRs with a 30" brush cutting width are preferable for heavy-duty use. Good luck in making your selection. /forums/images/graemlins/grin.gif
Brian, Thanks for the input. I read the entire thread You mentioned .
I was at first concerned about the skids on that machine . They do appear to be a bit weak in the pictures ,and look as if they might tend to get snagged up . But, after reading the above mentioned thread , it seems to be a non-issue. John
/ Walk behind brush mowers #9
NIXON,
I have broken off one of the skid metal bars ONCE in my several hundred hours of DR brush mower use during the last two and a half years; I was forcing it after a snag. But DR immediately sent out a new replacement brush deck cover with skids without charge, plus later I was able to reweld the broken metal skid onto the old cover for backup!
Even with the potential for very occasional snags and even less frequent breakage, I think their deck cover and skid design is close to optimum.
/ Walk behind brush mowers #10
I have Billy Goat model BC 2401H have had for about 2 years ,I purchased it used from a tool rental store does more than i ask it to , just aim it & hang on, it has a 11 hp honda engine. jim
/ Walk behind brush mowers #11
I too was in your position last summer and launched a similar thread. After having rented two machines; the Billy Goat - which just man handles you, after several hours I was exhausted. The Bachtold hi-wheel mower, was completely inadequate for any type of slope mowing. After researching Swisher, I felt that their support would be entirely inadequate. For instance, I called Swisher and requested a list of dealers here in CA. After calling several dealers, none of them knew that they carried such a product! Hence I looked for a DR, on ebay. And just last week purchased a 15hp Kawasaki for $1450, including shipping from WY. Haven't had the chance to use it yet, but it starts well, and I'm optimistic about its performance.
/ Walk behind brush mowers #12
For the last month I have been searching for a brush mower as well. I have narrowed it down to two brands.
The DR seems to be the mower of choice from all I have read. Being able to have other attachments is a plus. We have other DR equipment and never had a problem that did not get taken care of promptly.
I also like the looks of the Snapper. I think it's strong point is the hydrostatic drive. I also have a good Snapper dealer in the area that gave me a good price. I know if there is a problem it will be taken care of as well.
Has anyone had or still have a Snapper model?
/ Walk behind brush mowers #13
John:
You might want to look into the BILLY GOAT brand of walk behind brush mowers. I bought one last year and according to the specs, they say you can reclaim up to three quarters of an acre per hour with it.
This has been a great machine for me. 3 speeds forward & 1 reverse and I think the cut is about 24" wide.
It has a 13hp Kawasaki gas engine, elec start as well as recoil start, and two cutting heights. This is NOT a string mower...has an actual blade and I've cut thru 1.5" stuff with it. It's not a finish mower but if you're looking to reclaim land, you should give it a good look.
The only problem area is the size of the gas tank. You need to keep the gas can close by if you're doing a lot of work with it.
Jon
/ Walk behind brush mowers #14
Wingman1 and all,
For 2006, DR Power has added Lockable Differential and Electric Blade Clutch to its Field and Brush Mowers. /forums/images/graemlins/cool.gif This makes what I found to be the best walk-behind brush mower for heavy-duty use even better!
When you engage the differential you'll have have equal and maximum power at both wheels for added traction. Disengage the differential and the wheels turn independently, for easy turning and maneuverability.
There is now a Blade Control Knob on the control panel used to activate or deactivate the Electric Blade Clutch (which they say is now made by Ogura and is the same clutch that's been used on commercial salt spreaders).
Three problems I had with the Billy Goat Outback I rented (before buying a 17hp DR) were (1) awkwardness of engaging and disengaging the Billy Goat's clutch using your feet, (2) tendency of its rear discharge design to have tall, thick materials wrap around the the wheels/axle, and (3) its 24" cutting width not being as robust as units with 30" cutting widths.
I haven't seen many comments from owners of the Simplicity / Snapper / Ferris brush mower on TBN or anywhere. But since they are offered only with a 25" cutting width, they won't handle thick materials as well as the DR 17hp and 18hp models with 30" cutting widths.
/ Walk behind brush mowers #15
How big an area do you have to cut? We use these
http://www.stihl.us/trimmers/FS550.html
This is basically a skill saw blade attached at the end of a long turning pole. Everybody around here has one of these. We ahve to keep the land clear to prevent forest fires. And we dont' have grass around here, mostly brush type vegetation, and of course trees.
It gets into places no wheeled equipment could reach. So back to my question of how big an area to you need to clear?
/ Walk behind brush mowers #16
BCS makes a very heavy duty two wheel tractor. They are more heavily built than DR and Snapper brush cutters. More versatile as well with many attachments available, andsome models even have a diesel motor option. You can even get a wood spliters, wood chipper and even a hay balers for the larger variety. They are best known for their tiller attachment.
This is a Euro import where they still farm quite a few acres with this type machine. Goldoni is another Euro make that makes a similar two wheel tractor but they are not as readily available in the U.S.
They have brush cutters available up to 31 inches wide.
Here is a great website to read up on two wheel tractors and what they can do...
http://www.earthtoolsbcs.com/index.html
/ Walk behind brush mowers #17
Brian & aesanders
Thanks for the updated information on the DR. That is/was the direction I was headed until ........... I saw the BCS website provided by aesanders. Although out of my league .... it did cause me to dream! I still may sharpen the pencil and see what the numbers amount to for the BCS equipment. Having the advantage of multiple attachments adds to it's use.
/ Walk behind brush mowers #18
Rox,
We use those type tools as well. Once you cut the stuff down, then you have to do something with it (haul, burn, chip etc.). We live on 65 acres and we have machinery to take care of it. We have two smaller parcels that is near enough to haul what tool/machine is needed ( 20-30 miles).
We recently purchased 13 acres for a mountain get-away (300 miles away). Although I will probably haul the small tractor and bush hog (1720 ford) there to begin with, it will not stay. There are some areas a little to steep for tractor use, others near a stream that a tractor would do more harm than good.
With a walk behind we can be more selective in what gets cut down. It would also be used to create walking/atv paths where the height of the small tractor would not be feasible.
The more I search the more stuff I find to do the job. The problem is I would have to get a second job to afford all the stuff. I may have to stick to a axe and matches.
Rx it's kind of hard to put down into area . But 1-2 acres would best cover it . I've got a decent weed eater,and a 5ft BH . Ijust need to find something that will do those jobs that are in between the two .
The DR is very attractive to me . But,at 3k .... I've got to think about it for a bit . The Snapper is also attractive at 1/3 less . But will ti hold up ? In a lot of ways, this is worse than buying a tractor /forums/images/graemlins/smile.gif John
/ Walk behind brush mowers #20
If you just want a good brush mower, I would probablyget the Dr. It will definately cost less than buying a BCS. The DR is a good unit. However, if you see yourself with two, three or more types of equipment, the BCS starts to make a lot of sense. Their tiller is second to none. Brush cutters are very good. Even the snowblowers (single stage) is quite powerful. It's a good all around machine. I have a model 830 which is no longer made (similar to the 852 but less powerful with a 9hp briggs vanguard). The BCS machines are all direct drive so they are more powerful than similar machines with the same hp rating.
The local BCS dealer near me ( a John Deere dealer) has been selling them for 20+ years and say they are the best thing since sliced bread. They use one for their snowremoval around the facility. Says they work better than the 2 stage Frontier snowblowers they sell. This dealer told me they sell most of their's to professional landscapers as tillers, and to local farmers who do tilling, brushremoval and snowblowing around the farm.
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
New/Unused Wolverine Quick Attach Trencher (A61166)
New/Unused...
2016 Lincoln MKT AWD SUV (A61569)
2016 Lincoln MKT...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2006 Volvo VNM Day Cab Truck Tractor (A61568)
2006 Volvo VNM Day...
(2) 580/70R38 TIRES W/8 LUG RIM (A62130)
(2) 580/70R38...
