Walk behind brush cutter.
/ Walk behind brush cutter. #1
_RaT_
Super Member
Peoples Republic of Northern CA.
Kioti 3510-SE HST
I am aware of a couple of brands like DR and BCS, does anyone have recommendations on some other brands, comments about them. I am looking at the larger models with as much HP as possible. Thanks.
/ Walk behind brush cutter. #2
I bought the DR Brush cutter with the 17 HP engine a few years ago. The thing is a monster. It kicks a...s. It will kick your a....s. :D
There was an 18 HP Honda engine but it was quite a bit more money for one HP.
The DR will cut down the same sized saplings as my MX 6. About 2-2.5 inches. I also use it to mow the lawn. :D It is nice to know if the lawn gets long, say 24 inches, it really does not matter to the mower. :D:D:D
The DR does what it is supposed to do. I did by the generator a few years ago since it can attach to the engine. They know have a blade that looks interesting. :laughing:
I have only had two problems with the DR and one is my fault. The key switch jammed up on me because dust would get into the switch when the engine was turned off. The DR is in a shed an dust gets into the shed. I know keep a piece of tape over the key hole.
I ended up having to get a new assembly to fix this problem. DR did have GREAT customer service. They helped me shoot the electrical problem I ran into because of the gummed up switch. They really knew what they were doing. AND they told me I could likely get the assembly at Lowes, HD or a JD dealer. :thumbsup: I just bought it from them since it would save me a trip AND I would have what I needed.
The bigger issue is that the lid to the gas tank tells you how much fuel you have left. The problem is that the mechanism to do this is metal and sits in the gas. This metal has rusted on me and clogged up the fuel filter. Major PITA. DR sent me a new gas lid without a problem but the new assembly rusts as well. I just took apart the fuel gauge assembly. Now that the engine is broken in 2.5 gallons of gas lasts at least three hours. After 2-3 hours behind the DR *** I *** am out of gas. :D
The DR will work your fanny off. It is powerful. It will walk over you in reverse. The dead man switch is needed. The hand controls took some getting used too. I don't know if they got easier to use over time or if I got stronger, likely both, but my fore arms hurt bad the first 10-20 hours on the DR. Could have been related to my back injury as well.
The DR brush cutter has skids not tires up front. To turn you have to push DOWN to pick up the skids and then turn. It would be nice if the handle bars where an inch or so taller for me. That pushing down did not make my bad back feel good but I guess I got used to it. :D
I did have to buy some very good work gloves. the pushing down to turn will give large blisters on your hands. Given my space I am turning quite a bit which really can blister up your hands. And bother your back.
I run my DR in the yard but also in the woods and along property lines were the tractor cannot go. It is a beast. It chews up trees, grass and rocks. :eek: If it is tall grass or thick saplings you just have to put it in low gear and go slow. It does not bog down. If the grass is low enough and I use the DR on our road instead of the MX 6 four gear is a fast walk.
The DR does everything I would have expected. And more. I would guess that their returns are from people who cannot handle the machine. You really do have to watch it especially in reverse. It will push you over or into a tree. Anyone who disables the dead man switch to mow is asking to get seriously hurt. Mowing next to a tree you need to leave a bit of space because you can hit a rock or stump which tilts the mower and tosses your handed into the tree. Did I mention good gloves? :D
Later,
Dan
/ Walk behind brush cutter. #3
Another option is an older gravely with the 30" brush deck. I'd be looking for one with a kohler engine say in the 10-12 hp range. You won't be able to manhandle where it goes. You've got to control it. Sometimes dual wheels and chains are a big plus on a slope.
/ Walk behind brush cutter. #4
Plus, an advantage of older Gravely's is that they are absolutely bullet-proof; over engineered and over built to the hilt, AND there's lots of cool attachments for them that can usually be had for cheap (may require some re-conditioning;-). I especially like my 40" twin-blade finish mower, and the 48" sickle mower!
- Jay
/ Walk behind brush cutter. #5
Billygoat is another brand.
I aslo have the 17 HP DR, its pretty useful!
/ Walk behind brush cutter. #6
I am looking into one of the big ones as well. Does anyone have experience on steep slopes? Will they climb the hill or will they traverse the slope?
/ Walk behind brush cutter. #7
My dad has a Dr and we have used to go up and down a river levee.
every thing dmccarty said is true they are a beast, and well worth the money.
/ Walk behind brush cutter. #8
What Dan said..
They work. If they can push it over,they'll cut it.
They will kick your butt though... Its a work out:thumbsup:
/ Walk behind brush cutter. #9
I'll second everything dmccarty stated. I also once owned the 17HP model. Its a Hoss. Will handle more than you'd think at first glance.
Someone asked about slopes...did pretty good on some areas I had of 30-35% grade. Never had reason to use it anywhere steeper, so I never learned exactly what its true limits are.
Lost
/ Walk behind brush cutter. #10
Another vote for the DR. I have the 13hp version and it does just fine in all sorts of brush. Very reliable B+S engine. No problems over the past seven years which included two years of heavy use and intermittent use since. Only service besides oil changes has been fixing flats (despite slime).
Agree with all comments about what a workout the machine will give you on uneven ground. It drags you along and requires more than just arm power to change direction quickly or especially when reversing. I cannot imagine using something like the DR without a reverse gear though.
/ Walk behind brush cutter. #11
I have used a billy goat, and it did a pretty good job. But particularly on slopes or uneven terrain, you better be healthy, in good physical condition, and prepared for some VERY physical work. It kicked my butt! That was before I got a tractor... In my case, I find that in almost all circumstances, I can back the brushhog up the slopes and cut that way. Way easier from a tractor seat, but the walk behinds do have their uses if YOU are up to the task. I would highly reccomend trying one from your local tool rental before you buy one.
/ Walk behind brush cutter. #12
I used a borrowed a Gravely to make paths etc and it worked well but I fully agree with RonMar -- the tractor is a lot better. Now I have an Ariens walk behind trimmer that I use with a blade on for areas that the tractor won't reach.
/ Walk behind brush cutter. #13
Regarding slopes. I have very little flat ground but I would not call what we have real slopes though there are some sections that are sloppy. :D
Cutting with the DR ACROSS a steep slope might be interesting. I could see that it would want to head down hill and you would have to counter steer which would not be fun if you have to spend much time on such a slope. I do think it would have to be a pretty decent slope for this to happen though. The skids up front DO NOT want to allow the DR to go left or right which is why you have to push down to life the skids to turn.
On the other hand the DR would go up the slope easily. I swear this thing could almost climb a tree. :D I have gone after saplings that instead of getting cut just bent over and the DR rode right up on it. :confused2: I wish the DR had a LOW first gear sometimes. :D
I don't like buying used. It is just me. :) We do have a used car but its the Wifey's. :D Knowing what I know now, if I was buying a DR today I would seriously look at one of their refurb models. I would bet that most if not all of the refurbs are mowers that people could not physically operate and they returned them to get their money back.
Later,
Dan
/ Walk behind brush cutter. #14
Why are you interested in a walk behind brush cutter? Might help to know what you want to use it for.
If your asking me then its simple, we have 2manyrocks :laughing: on our 180 acres of semi maintained area that the tractor simply cannot approach. We use a Kubota L3940 with a 72" flail mower to take care of 90% of the work, a Honda weed eater with a blade for some stuff and a Stihl weed eater that does a ton of weed eating....
/ Walk behind brush cutter. #16
What's worse is those rocks have a year round mating season, with an extremely short gestation period. Honestly, there were only two there yesterday, but now there is a dozen :eek:
/ Walk behind brush cutter. #18
They really are a workout. Would an ATV pull behind unit work for you?
I have both the DR walk behind and the DR pull behind.
I definitely second everything that's been said about the walk behind. Goes about anywhere, cuts about anything, but does give you a real workout on rough terrain. Mine has done many miles here on the farm as well as on state forest bridal trails. Just wears everyone out, LOL.
I've had mine ten years. Oh, btw, when I bought it, I also ordered the "heavy duty blade". I've never taken that out of the packaging and I've never sharpened the original blade even though it's taken on a hidden concrete block....and won! (Rounded off the corner of the block.)
The tow behind has been a major disappointment. I really should have sent it back, but it was too big to get repackaged and loaded up. First of all, it's too heavy to be towed with a 4 wheeler on hilly terrain. First time out, the 4 wheeler couldn't pull it up a moderate grade on our trails and I had to get a second 4 wheeler to assist. I now pull it with a Kubota RTV900 utility vehicle. The original hitch was horrible (they've changed it). It doesn't cut near as low as the walkbehind or a bush hog, so it isn't ideal as a trail mower. I've had lots of problems with the control cables. Right now I have about a half dozen replacement parts to go on it. It just isn't in the same class as the walk behind.
Ken
/ Walk behind brush cutter. #19
I had the DR walk behind. What a beast of a machine. It had the differencial lock which was crucial for me with my slopes. I didn't have enough area for it so I sold it. I rolled once when working too steep. That thing rolled over and over and landed upright. Not a dent, scratch, nothing. It was expensive but worth the money.
/ Walk behind brush cutter. #20
I rented a "Billy Goat" http://www.billygoat.com/site/categoryLobby.aspx?lid=9 before purchasing the tractor. It worked but it did indeed kick my butt. It is hard to maneuver and I don't think it can go too many more places than your tractor could. With the cost vs. benefit while having a tractor, IMHO I think purchasing a walk behind while having a tractor would be a waste of money unless you have plenty to burn.
As someone else has mentioned, rent one first to see if it will do what you want it to do.
Good Luck!
Bobcat MT85 (A60462)
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
207278 (A52708)
207278 (A52708)
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
