Waking up an older Troy-Built horse...
   / Waking up an older Troy-Built horse... #1
timb
Veteran Member
Southwest PA
Deere 4710/reverser, JD 318 (still needs TLC), JD LT160
Troy-Bilt "experts":
I've inherited an older (1979-1980?) Troy-Bilt Horse tiller (7 hp Kohler). It was always well taken care of but has been stored without being run for at least 5-6 years (under cover). Probably wasn't run out of gas dry before it was stored. I want to get it back in service for this year. Other than the usual procedures for waking up a gas engine (shot of oil in cylinder and cranked without the plug a bit, change the oil, clean the gas tank/lines) anyone know of anything specific to these Kohlers or the tiller gearbox that I should do or look out for? Like seals that are known to be trouble, etc.,? Have no idea of the drive belt age but I did notice that the pulley is pretty badly rusted. (The rest of the tiller is pretty clean).
Anyone know where I can get an owner's manual? The original is supposed to be around somewhere but I haven't found it yet.
Tim
   / Waking up an older Troy-Built horse... #2
I can't really help you with specifics, but I've read a lot of posts on garden-related sites that praise the 7 hp Kohler as a bulletproof engine. I don't own one, just repeating what I've read.
The engine was always solid "back in the day" - my biggest concern is that this tiller hasn't really been run much lately - and probably wasn't "archived" correctly. In fact I believe it sat for a few seasons - then was pressed into service once without really going over it - and now it has been idle for another couple of years. So - I'm thinking corroded bore, stuck valves, gummed up carb, all sorts of things might have crept in. On the other hand - I won't know until I try - a little careful wake up and it might run strong as ever.
Tim
   / Waking up an older Troy-Built horse... #4
The quintessential answer on manuals, Tim, is nearly always: e-bay. It's worked for me it the past.
   / Waking up an older Troy-Built horse... #5
Hi Tim, the bore, valves should be just fine, unless it has sat outside in the weather for the last several yrs. Your problem areas will more than likely be fuel tank, fuel line & carburetor.
   / Waking up an older Troy-Built horse... #6
I own a 1980 horse with the same Kohler. Mine sat a couple of years indoors and needed the carb torn down and cleaned and rebuilt because of excessive varnish. The manual says to shut off the fuel at the bottom of the tank and run it dry before storage, but I forgot. The carb parts were gosh darned expensive as I recall. When changing the oil, lift the opposite side wheel to tilt the engine toward the drain to get ALL the old oil out. Now with the tiller level, the dipstick is placed vertically in the hole WITHOUT threading it in to check level of oil per my manual. Use a good 30 weight. The gear box lube is a 80-90 weight gear oil (140 weight was the original oil from the factory and recommended in hot climates or for commercial use) and with the unit level in all directions, you would remove the upper check plug. If a little bit of oil starts coming out the bottom of the hole, it is full. Since it sat this long, I'd probably change the gear oil too. A new air filter, plug, points and definitely a new condenser are a good place to start. I just priced new tines at $122 from my local dealer, so it looks like ebay is a better choice. If you have never run one of these old Kohlers, they don't really sound like a mower engine, more of a thump thump thump sound. Not a real high RPM motor, but LOTS of torque. With all new lube and ignition parts you should be ready to go. Don't forget that there is a fuel shut off on the bottom of the gas tank! Make sure it is open when you try to start it. You got a great tiller! Mine is still running strong and no reason it won't last another 25 years.
   / Waking up an older Troy-Built horse... #7
One thing I forgot, you can get the tiller manual from MTD's web site. That will cover the tiller proper. You might get the Kohler manual from their web site, but I am not sure.
bontai_joe
Thanks for the refresher. I ran this tiller myself many hours many years ago (it was my parents) so I remember it. I even did the maintenance 20 years ago but except for the straight 30W engine oil I had forgotten the details without the manual.
Based on how well this tiller worked I always talked up Troy-Bilts. Imagine my surprise when my father-in-law bought one of the new smaller units a few years ago. I took one look and clamed up without comment. There is no comparison.
Hopefully the beast will wake up gently and well-rested (not rusted).
The only problem I ever had was trying to till my Mom's garden for the first time one season after a farmer neighbor had graciously spread a couple inches of manure. Ever experience what happens with a rear-time tiller when the tires can't hold it back? /forums/images/graemlins/tongue.gif
At least I avoided going face-first all the way down! /forums/images/graemlins/crazy.gif
   / Waking up an older Troy-Built horse... #9
I have a K241 10 horse Kohler on my welder. Kohlers are bulletproof.
I'd get a pint of Chemtool. It's available at Murrays and mix it with some gas and run it through the carb if the engine will start. That will remove the varnish. If not, disassemble the carb and clean the parts in the Chemtool. Flush the inside of the gas tank with the Chemtool too.
As far as the bore or valves, just roll it over with the recoil and the sparkplug out. Put your finger over the hole and feel for compression. It should be okay. Before you start it the first time, you might have to replace the points and condensor. They are readily available at NAPA or Murrays.
Also, you might want to mix a little 2 stroke oil in the gas the first time. That will help lube the cylinder wall and rings as they have sat in one spot for a long time.
You also need to change the tiller gearbox oil. That's something that people never do. Use a good grade of SAE 90 weight GL 4 or 5 hypoid oil.
I had a horse a long time ago. Was a good tiller. Sold it for more than I paid for it.
Daryl,
Good idea on the 2-stroke mix. Hadn't thought of that. Never used Chemtool but if I can avoid having to strip down the carb, so much the better. I do plan on changing engine and tranny oil prior to trying to start it - I thinking of changing them (at least the engine oil) again after running it back in for no more than one or two tanks of fuel. Not sure what kind of junk might get shaken/scraped loose in there.
Tim
   / Waking up an older Troy-Built horse... #11
Tim,
I have a 71 vintage Troy built with a 6 HP Cast iron Tecumseh on it. Still going strong /forums/images/graemlins/smile.gif And yes they do lunge a bit when hitting a root or something and the tires can't hold them back. Still a LOT better than wrestling a front tine tiller. The newer Troy Built tillers are nothing like the older ones. Not sure if anyone mentioned this but check/clean out the cooling fins on the motor good. Might smell cooked mouse and overheat the motor otherwise.
Good luck and happy tilling.
   / Waking up an older Troy-Built horse... #12
... and in case of cooked mouse, keep a bottle of ketchup at the ready. As Andy Griffith used to say, m-m-m-m good!
   / Waking up an older Troy-Built horse... #13
One thing worth mentioning is that the drive for the tiller shafts on the older-good troy bilts is a bronze worm. The worm lies at a 90 degree angle to the tine shafts. There are 2 seals, one on each tine shaft that contain the hypoid oil. I ruined one seal on mine when I inadvertently wound a coat hanger around the tine shaft and it rubbed the rubber seal. You do have to watch for any foreign objects that might get wound around the tine shafts. They can destroy the seal in short order.
If you can, remove the tines from the tine shafts and coat them with never seize and put them back on. Chances are they are already frozen to the shafts. If they aren't, put on the never seize so if you ever have to work on the final drive, you won't have to cut the tine carriers off.
Daryl,
Good point. I know we replaced the tines themselves once after wearing out the original set - but I doubt we ever pulled the carriers off.
OK - really dumb question. I just looked on my "supplies" shelf and I have two weights of hypoid oil. One is a "75W-90" and one is an "85W-140". If the tiller calls for 90W under normal use/temp conditions - which is the better choice? (Both are GL5 hypoid). I think I'd lean toward the heavier - especially to compensate for older seals - but is that too heavy in this application?
Tim
   / Waking up an older Troy-Built horse... #15
My new Troybilt Bronco calls for 85-140 GL-5 oil if replacing the entire gear oil supply. Apparantly that is the original oil in the tiller. 80-90 was o.k. if adding only a few ounces to top it off, according to the manual.
I'm pretty impressed with the new tiller. The drive shaft looks very durable and at least from the description and drawings in the manual appears to be the same as the "old" tillers. Add that to a 5.5 hp Intek OHV and it seems like it should last.
   / Waking up an older Troy-Built horse... #16
Tim:
I'd go with 75/90 rather than the 85/140. Here is why. The GL5 or 4 rating for that matter indicates the relative resistance to shear and the lubricity. That is an API rating, obtained after extensive 1st. article testing.
You live in a relatively cold climate. The 85/140 will be extremely thick and resistive to movement and circulation in cooler temperatures like in the spring and fall when you are going to use the tiller the majority of the time. Because of the resistance the 85/140 would put on internal components, I think you'd run a higher risk of damaging a seal than with the lighter viscosity oil. Remember, the API rating is GL5 for either lube. The 85/140 will also absorb more horsepower from the engine allowing less horsepower to travel to the tines especially when cold. I always thought that 85/140 was a better choice than 75/90 or 80/90 too. I had a scenario a few years ago. In short, here it is...
I had a small Japanese car with a 5 speed manual gearbox. The box called for straight 90 weight GL4-5 hypoid oil. I though that 85-140 would be better. It was fine in the summer. Winter rolled around and one morning the ambient temperature was about 5 degrees. I was getting ready to go to work. I started the engine with the gearbox in neutral and the clutch depressed. The clutch had an interlock. After the engine started, I let out the clutch and promptly spun the clutch. The internal resistance that the cold 85/140 put on the pilot shaft as well as the gears, overcame the clutch. $400.00 later and a new clutch as well as the recommended 90 weight in the gearbox, I was ready to go again. Motto of the story, sometimes it's better to use a lighter gear oil, especially if the owners manual calls for it.
After a 10 year (?) snooze, it's awake! /forums/images/graemlins/grin.gif
All it really took was some fresh gas, a plug cleaning, and some air in the tires. The engine oil was very clean, at the right level, and showed no sign of contamination that I could see. (The gas tank shutoff had been left open with about a quart of gas in the tank).
Shot a little spray gumout into the carb throat, then dropped a capful of 30 weight into the cylinder and cranked that around a bit with the plug out - then let it sit for a few hours while I took care of other chores. Repeated that step 1 more time - then after checking over things to make sure that bolts that were supposed to be tight were and pivots that weren't, weren't - I gave it a try.
No go - so I gave it a very short burst of starting fluid and it would pop a few times, actually blowing some of the added oil right out the (rusted out) muffler). A couple of tries later I was up to about 5-10 seconds of running before it would quit. Cleaned up the plug again - and it fired up for good. All the oil burned off fairly quickly and it settled out pretty well.
Took a little bit to shake the rust off the drive pulleys but I ran it around the yard for about 10 minutes forward and reverse - then tried it under load even though it's far too wet here to till yet. It settled right into the load without issue and would idle like a watch at the far end of the row.
It's going to get a full fluids change next week, a muffler, and a new air filter. I'll pick up a point/condensor set but I may not change that until I need it. Anyone know where I can get a gas tank shut off valve? This one just spins in place.
No other issues spotted, no leaks anywhere. Guess it's hard to keep a cast-iron old-fashioned Kohler down. /forums/images/graemlins/cool.gif
   / Waking up an older Troy-Built horse... #18
/forums/images/graemlins/cool.gifGotta love those old iron Kohlers. They are hard to kill, put out all the torque you will ever need and are easy to work on. I'm very glad to hear that you got it running and also glad to hear that you are gonna change all the fluids and out in fresh. Small price to pay for an engine that has been sleeping so long. /forums/images/graemlins/smile.gif
I'm glad it's going again as well... brings back good memories. Technically this was my Mom's tiller and although she was an avid gardener she never ran it herself.
When my brother and I ran this tiller for her back in the late 70's / early 80's (figured out it's a 1978 model) we changed oil at least twice a season. This tiller always got great maintenance back then. Never sat outdoors, and it was always put away in the off-season with all gas run out, fresh oil in the case and a shot of oil in the cylinder. By the late 80's Mum wasn't gardening much anymore and it sat for maybe five-six years. Then it was run once by a neighbor for my Mom without any prep when we weren't around and she got a notion she wanted to try a small garden again. Far as I know it sat untouched (under cover) for the 7-10 years since. So far it doesn't seem much the worse for the slumber.
I know Mum would be glad to hear it thumping along again.
Tim
   / Waking up an older Troy-Built horse... #20
Any small engine repair shop should have the shut off valve that screws into the bottom of the tank.
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
Sakai SW354 (A60462)
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
