W.R Long 3rd function remote issue and resolution
/ W.R Long 3rd function remote issue and resolution #1
sdef
Platinum Member
SC
2013 Kioti DK45SE HST
Really long story short- new tractor, new W.R. Long 3rd function remote at the FEL and new rock grapple bucket. System worked fine for first couple hours of intermittent grapple operation. I didn't like how the electric button worked, with press the top rocker switch position to close the grapple and press the bottom of the switch to open it. So I took the FEL control handle apart and swap the wires on the switch. When I put it back together, now the grapple intermittently and consistently will not work.
Over the last 10 days the hydraulic cylinder would intermittently do the following and not in any particular order, nor associated with any apparent action on my part:
- Would extend and not retract (most of the time)
- Would retract and not extend (some of the time)
- Would retract very slowly, taking ~ 60 - 90 seconds to open the grapple fully (rarely). And the solenoid/valve assembly did not make its typical "clunking" sound when activated. I had plenty of hydraulic fluid and no other function on the tractor has issues. I was able to raise and lower the 710# RO BB at will with no issues, along with the FEL.
- Most of the time the electric/hydraulic solenoid would make its "clunking" sound when the cylinder was activated, as expected, but sometimes it would not. When it was not making its normal sound, it usually was associated with the cylinder not working properly, but not always.
Initially I thought the dealer had installed the electrical Faston connectors incorrectly, as the problem started after I switched the terminal connections around. And then I thought with the cylinder extend and retract issues, the common point would be 12VDC power, which is common, as the solenoid provides ground. I even stripped some insulation back from the wires close to the solenoid and verified the wiring was good to that point at the sealed inputs, to no avail.
At this point I was convinced it was not a power problem and not something I had done when I switched the connections in the FEL handle. But is sure was quite a coincidence.
I also did not think it was the solenoid as there were issues in both cylinder directions and it was unlikely two fairly discrete circuits would have the similar failing issues.
By this time I figured the hydraulic valve was probably actuated magnetically and was the "clunking" sound I was used to hearing upon activation. And that everything from the solenoid back to the loader handle was good.
Now this only left the actual hydraulic valve assembly, which I knew nothing about its internal construction as this is my first brush with hydraulics. In my mind I pictured the valve with a single piston, operating within a single cylinder. And when the solenoid was activated. the piston would be pulled one way or the other, which would open an exit port and the fluid would flow out that port. Else the piston would be centered and blocking both exit channels. With this in mind, I came to the conclusion the piston and its bore were either in a situation of stacked clearances causing too little clearance or else a machining issue with a burr or something left at an interference point.
My very good dealer who is 150 miles away also felt the issue was in the valve assembly and he was going to have Long's ship me the entire assembly and I would replace it.
Long's and my dealer wanted me to check a couple more things, one of which was to disconnect and reconnect the 3rd function remotes at the grapple cylinder and also at the junction point that would allow the FEL to be removed. My dealer, Ron at West End Sales (great folks) told me he has never seen a bad W.R Long hydraulic valve or solenoid assembly and that they install a lot of them- but there is always a first... He further stated that he has seen a 100 or more times of hydraulic failures in the quick disconnect hydraulic coupling. Apparently if one of the coupling ball assemblies fails to mate properly when the male and female portions are connected, it can/will cause hydraulic flow failures. And their mechanic also said that a coupling being hit hard with something could unseat the connection just enough to cause hydraulic flow failures, yet may not leak fluid nor show any signs of a physical problem.
I was dubious, but dutifully did all that was asked, which included reseating these two pairs of hydraulic fittings. I did notice that one coupling (1/2" flat face skid steer) at the grapple was difficult to release and may have had pressure on it. I fiddled with it for a few minutes and rotating the collar seem to free it up and I was able to complete this task. I did not lose any hydraulic oil.
I started the tractor and the grapple worked perfectly. I then took it out to do a little work and it still functioned perfectly. I hope it stays fixed and that a coupling issue was the culprit. But am leary as the issue originally did not crop up for several hours after first use. But it has been more reliable now than it ever was. Time will tell.
Also, as a troubleshooting aid for the W.R. Long solenoid, if one presses in with a phillips screwdriver on that small brass button at the end of the solenoid, it is supposed to activate the valve in one direction and then one can press the same type of button on the other end of the valve to move the cylinder in the opposite direction. I have yet to try this but it is an excellent troubleshooting tip.
/ W.R Long 3rd function remote issue and resolution #2
Reseating Quick Couplers is one of the first things you will see for problem solving in hydraulics on this Forum. I think the "low bid" (Cheap) QCs are what cause a lot of problems.
Thanks for posting your experience.
/ W.R Long 3rd function remote issue and resolution #3
I'm having the exact same problem with my 1/4" quick connects on my grapple. Is acting as if the fluid is pushing the ball closed when I activate the valve fully. If I feather the grapple slowly it works fine, but if I activate the valve fully, it slows down. This started happening after I removed and reinstalled the grapple recently. I tried re-seating the quick connects then it finally started working but, I have to feather it slowly. Could there be some trash from the quick connect covers possibly that is preventing flow? I haven't tried just removing the quick connects but that maybe my next step.
/ W.R Long 3rd function remote issue and resolution #4
l recommend you go to the next size QD, or if you don't disconnect often, go to a swivel coupler.
The volume of fluid is probably closing the ball or poppet
/ W.R Long 3rd function remote issue and resolution #5
l recommend you go to the next size QD, or if you don't disconnect often, go to a swivel coupler. The volume of fluid is probably closing the ball or poppet
Could it just be a faulty quick connect, or do you think it's actually sized incorrectly?
So far so good. The grapple is now working 100% after reseating the couplers the other day. My couplers are 1/2", flat face skid steers. On the tractor they are U.S. made Dixon and on the grapple they are Italian made Stucchi.
/ W.R Long 3rd function remote issue and resolution #8
I installed a WR long 3rd function valve this year as well and had the same problem after a few hours of operating. WR had great service but also told me they never see problems with their valves. I banged on the brass push pins with a punch and it worked again after that. Then stopped again. Banged on the brass pin again but it didn't work again this time. They sent me a new valve and I installed it. Checked the couplers. ( did notice one of my my backhoe couplers had become slightly disengaged somehow. Connected the 3rd function couplers together and flushed the valve with new fluid. (my guess was some teflon got stuck in the valve)
After all this it has worked great!
The flushing of the fluid i think was key. Check couplers (all of them everywhere!). Take apart the valve and clean is last resort. Dont hit the brass pins too hard or you'll mushroom them out. Light taps with a rubber mallet and punch that fits.
Good luck anyone who has to go through it!
I also had a problem with my WR Long remotes after a couple hours of initial use. I worked with my dealer and they got Long involved, who was going to send me a new valve block. As a last check, I was asked to remove and reinstall the QDs going forward at the FEL arms. I removed and replaced with everything seeming normal. However, after doing this the WR Long remotes have worked perfectly for the last 350 hours. I do not know the mechanics involved, but now know that even though remotes appear to be connected completely, they may not be. I am pleased with my WR Long remote setup for the FEL.
2026 XStar 750 Gal Fuel Trailer (A64119)
2026 XStar 750 Gal...
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59912)
2022 GREAT DANE...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A61572)
2025 BS43 44in...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
58in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
58in Hydraulic...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
