Victory BCRL-155 Flail for Weeds & Kubota L3710
   / Victory BCRL-155 Flail for Weeds & Kubota L3710 #1
Suburban Plowboy
Platinum Member
FL
Kubota L3710
Figuring things would never get cheaper, only more expensive, I ordered a Victory ditch mower. On advice from Victory, given that I have a Kubota L3710 with 30 PTO HP, they suggested the BCRL-155 (60"), which is a standard duty job that weights 672 lbs. They have a more expensive mower called the TRIM-56 which weighs 640 pounds and has a 56" cutting width.
They said 1) Y-blades were only good for grass, and 2) the mower should not exceed 30% of the mower's gross weight. I believe my tractor's gross weight is about 4,500 pounds with the loader and filled tires, so the BCRL-155 would hit 15% of that.
My main problems are weeds, some of which have woody stems that can approach 3/4" in diameter, and general cleanup.
Let me know if this sounds like a good choice. I am eager to take my pasture back from the blackberries and beautyberries.
   / Victory BCRL-155 Flail for Weeds & Kubota L3710 #2
I take it that you are getting the hammer blades not the Y blades.
Yes. I took their advice.
I tried to find out what the difference between a BCRL-155 and a TRIM-56 was, and they told me it was negligible.
I'm looking forward to getting this thing. I have a bush hog, but it's enormous, it's very dangerous, and all it does is rip things off coarsely about 8" above the ground. I want to see blackberry briars ground off close to the dirt and turned into unrecognizable slaw.
   / Victory BCRL-155 Flail for Weeds & Kubota L3710 #5
Please update us on your purchase and thoughts. Thanks and good luck!
I haven't even hooked it up yet! It's sitting in the crate.
August has been a month of challenges. I managed to get my used Kubota ZD326 fixed up to where it functioned, and I finished installing the rear remotes on the tractor. Maybe I can get the flail mower going this coming week.
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
2014 John Deere 630FD Draper Head (A53342)
2014 John Deere...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
