Victory BCRL-155 Flail for Weeds & Kubota L3710
   / Victory BCRL-155 Flail for Weeds & Kubota L3710 #1
Suburban Plowboy
Platinum Member
FL
Kubota L3710
Figuring things would never get cheaper, only more expensive, I ordered a Victory ditch mower. On advice from Victory, given that I have a Kubota L3710 with 30 PTO HP, they suggested the BCRL-155 (60"), which is a standard duty job that weights 672 lbs. They have a more expensive mower called the TRIM-56 which weighs 640 pounds and has a 56" cutting width.
They said 1) Y-blades were only good for grass, and 2) the mower should not exceed 30% of the mower's gross weight. I believe my tractor's gross weight is about 4,500 pounds with the loader and filled tires, so the BCRL-155 would hit 15% of that.
My main problems are weeds, some of which have woody stems that can approach 3/4" in diameter, and general cleanup.
Let me know if this sounds like a good choice. I am eager to take my pasture back from the blackberries and beautyberries.
   / Victory BCRL-155 Flail for Weeds & Kubota L3710 #2
I take it that you are getting the hammer blades not the Y blades.
Yes. I took their advice.
I tried to find out what the difference between a BCRL-155 and a TRIM-56 was, and they told me it was negligible.
I'm looking forward to getting this thing. I have a bush hog, but it's enormous, it's very dangerous, and all it does is rip things off coarsely about 8" above the ground. I want to see blackberry briars ground off close to the dirt and turned into unrecognizable slaw.
   / Victory BCRL-155 Flail for Weeds & Kubota L3710 #5
Please update us on your purchase and thoughts. Thanks and good luck!
I haven't even hooked it up yet! It's sitting in the crate.
August has been a month of challenges. I managed to get my used Kubota ZD326 fixed up to where it functioned, and I finished installing the rear remotes on the tractor. Maybe I can get the flail mower going this coming week.
TEYME 2000 E0L0 GTE10 LOT NUMBER 228 (A53084)
TEYME 2000 E0L0...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2016 MACK CXU613 DAY CAB (A52576)
2016 MACK CXU613...
