Victory at last!
   / Victory at last! #1
TC18guy
Southern Michigan
NH TC18 Hydro
A tree man offered to grind this stump, remove the roots, and leave the ground ready to seed for $150. The only mistake he made was telling me I would get this out with my 18hp "garden tractor". That's all I needed to hear. Of course it took me about 20 hrs and cost me a drawbar and 2 days worth of back pain. But it's all worth it, right /forums/images/graemlins/smirk.gif
   / Victory at last!
Ok, the attachment didn't work
   / Victory at last! #4
So what happened to the drawbar?
   / Victory at last!
It's a TSC model, but I'm suprised that it didn't outlast the chain I was using.
   / Victory at last!
I messed up the ball joints on the 3pt ends a little bit to. I had to drive out the broken end of the drawbar with a hammer and grind out the inside of both 3pt ends so that the joints would swivel like they're supposed to.
The drawbar bent when I was pulling the big roots away from the tree. It finally snapped as I was trying to jerk out the stump. I had already cut all of the roots except the tap root.
The only thing left to do was to try the truck. I ripped up the tap root after a few good yanks in low range 4wd.
   / Victory at last! #7
Darn..... You did some yanking with the TC-18.
   / Victory at last! #8
I have done similiar bullheaded things, still do sometimes /forums/images/graemlins/smile.gif I think it would have been better to pay the guy and have a cold drink while you watched him /forums/images/graemlins/smile.gif
   / Victory at last!
That's exactly what my wife said! I couldn't let him do it though after he told me I couldn't.
   / Victory at last! #10
well i can tell by the way your drawbar is bent that the pull wasnt pulling in the proper direction on the drawbar, a drawbar is strongest across the wide direction, like if you have a clevis on it then you are pulling inline with it properly, but if you just wrap a chain around it then you can bend it like you did. i have a 105 hp tractor and with that i did bend one cat 2 tsc drawbar using it the proper way with a drawbar hook, but i later bought a better grade tisco drawbar and have never had a problem with it. that tsc drawbar woulda been fine on a 18 hp tractor had you pulled on it in the proper direction, its only strong in one direction, just like a 2x4 is alot stronger on edge than laying down flat.
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51691)
2008 Ford F-750...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
CAT 279D (A50123)
CAT 279D (A50123)
2015 Ford Transit 250 Cargo Van (A51692)
2015 Ford Transit...
