Very Slow loader..... Help JD420 Backhoe
/ Very Slow loader..... Help JD420 Backhoe #1
Reaney in NH
Newport, NH
John Deere 420 Backhoe
I purchased with this problem, I will do my best to explain.
early 80s JD410 Backhoe..... Backhoe, Reverser, Steering etc all work fine.
Front loader is VERY slow.
I am told this happened after a clutch install....
I am a retired Master tech for Autos... limited experience with Hydraulics. Im sure I can fix it... once I find a place to start.
Thank you
/ Very Slow loader..... Help JD420 Backhoe #2
410 hyd system is closed center with a trans pump(low pressure) that lubricates the trans plus supplies oil to frt pump that creates the high pressure. Sometimes on clutch R&R the hyd lines(parts key 16 & 20) have been inserted in the incorrect holes when tractor is slide back together. Normally when this happens no hyd's operate. How long since hyd filter was changed and sump screen(parts key 15) checked? I would also suggest to check stand-by pressure which should be at least I'm guessing 2350 psi but my knowledge of JD ind tractors is limited as I was formerly employed by an "ag only" dealership. There's also a pressure control valve(photo 3) down by hyd filter but it is designed to give priority hyd pressure to steering except it has fitting(parts key 16) that ag tractors don't have that I know not it's purpose.
Thank you.... Very helpful.
Update..... I like to post results incase someone else runs into the same problem....
Its fixed.... I removed the Prioity valve and took it apart very carefully.... #6 in the above diagram was lodge in the tube sideways. The prev person did not get it in straight... it was actually stuck. I had to knock it pretty hard to get out. the edges were rough. I filed down the rough edges... reassembled correctly... and it works great.
Your advice was spot on.
Now to fix the blown up rear diff.... That the guy told me was a Planetary gear.... $1100 in parts alone... UGGGG
/ Very Slow loader..... Help JD420 Backhoe #6
Thanks for the update. I never witnessed many pressure control valve problems when I worked at dealership. Have you considered acquiring a differential from a salvage yard?
I'm pretty sure this was self inflicted by the idiot I bought this from. Good thing I got it Cheap. LOL
Im just starting the search for the Diff.... Can you or anybody rec-amend a salvage yard that will ship?
/ Very Slow loader..... Help JD420 Backhoe #8
IMHO buying a JD tractor with closed center hyd's that has hyd PROBLEMS is not a wise decision. Maybe you'll be LUCKY.
If you dont have something positive to contribute why bother?
It cost me nothing but time to fix the Hydro problem... I now have a useable Backhoe and front loader.... That will drive and dig.... and I get less then $1600 invested.... So tell me Mr Smartass... how is that a bad investment?
Even if I have to buy a NEW Diff for $1000.00... Im still into a great running hard working machine for cheap money and some time.
/ Very Slow loader..... Help JD420 Backhoe #10
Reaney in NH
I wasn't trying to belittle your purchase as on this purchase you did well and please accept my apology for offending you.
My point is unknown non-working closed center hyd systems can turn into a NIGHTMARE. If the system had been previously water contaminated this can cause premature failure of brake/clutch linings then the wear from metal on metal causes metal filings(fines) to contaminate entire hyd system causing every hyd valve & pumps to require cleaning/repair or sometimes replacement. This can take a lot of labor & $$$$$$. But congratulations on you current purchase I think you lucked out.
Jim
Apology excepted.. Thank you.
I have spent most of my life picking up other peoples junk and cast offs.... Fixing them... Using them for my needs... Reselling for a profit and moving on to the next project.
Backhoes like this sell for $8,000 or more.... I simply cant afford those.... So I work with what I can.
I appreciate real input... good or bad. Information... good or bad is power. These sites are awesome for gaining information. But simply stating something is bad or scary without giving the reason is unproductive for everybody. My Apologies if I over reacted.
/ Very Slow loader..... Help JD420 Backhoe #12
My input is as real as my JD experience. No apologies required on my end as sometimes I have problem expressing my knowledge without disturbing people.
Have a nice day,Jim
/ Very Slow loader..... Help JD420 Backhoe #13
That was a rather snotty and ungrateful reply to a person who shared decades of wisdom for free so you could repair your tractor in a few hours instead of days. with minimal expense in new parts . Every single word Txjim said was true about purchasing a tractor with hydraulic problems. Goodness knows the countless dozens we have dealt with here before .
The JD web site has a free parts book and parts interchange research tool. There should be all kinds of donor tractors . Beware of those with worn out brakes that have ground up metal in the transmission and hydraulics.
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
17101 (A55851)
17101 (A55851)
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
26120 (A56859)
26120 (A56859)
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2019 BOBCAT T740 SKID STEER (A62129)
2019 BOBCAT T740...
