Very high engine oil level
/ Very high engine oil level #11
If the hydraulic pump is mounted to the engine aux drive pad, and the shaft seal goes, it will fill the engine with hyd oil. ISZ
Local dealership has concluded the pump is at fault. They quoted 2200 pls tx to replace the pump. Ummm....No thanks.
Im taking it home and will try to rebuild with new gaskets and orings. Ive never taken a hyd pump apart and dont know what to expect. The svc manual is not very descriptive either and theres nothing comparable on youtube i could find. I guess ill see what happens when i start taking it apart. I may come back to this forum with some pictures and more questions...
/ Very high engine oil level #13
Were you able to get a price on just the pump? I know the pump on my Kubota is about 700, 2520 should be pretty similar. Hard to believe labor or the part cost much more.
i can get a jd factory part from other distributors for about 600 usd. Dealers here charge way too much.
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pick-Up Truck (A60352)
2023 GMC 1500...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
2020 Deere 544L (A60462)
2020 Deere 544L...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
2005 Ford Excursion (A60352)
2005 Ford...
