VERY expensive beet juice!
   / VERY expensive beet juice! #201
So I have to ask, has anyone ever tried to lay the tire on it's side and break one bead and just pour the fluid in? You would need another tractor to lift the tire back up but it would make filling the tire very easy.
   / VERY expensive beet juice! #202
One would think it would work. Whether it would wind up being any faster, let alone, easier, I kind of doubt. But then, I'm rarely in a hurry.
   / VERY expensive beet juice! #203
I didn't do it with a 'large tractor tire' but the concept is the same as I did with my old Cub Cadet.
I filled mine with WWF at that time, and I paid 49 cents per gallon when I did it................that should give a good timeline.
Ya don't need to break the entire bead............just enough to pour the fluid in.
   / VERY expensive beet juice! #204
It's apparent that some in here don't understand Koi:laughing::laughing::laughing:
Here is just one site for ya: Pan Intercorp - www.koi.com - Koi fish for sale online. Quality Pond Grade Koi, World Class Tategoi Koi & Grand Champion Koi
Now Iffn' ya get time...........check out 'Show Koi'
Thats nuts...
And im a "Fish Guy" . Kept fish for the last 20 years. so i know the prices of tropicals. $25 Angels are my limit.
Tying that kind of coin up in an outside fish that can go TU, fly away or get eaten by the neighbours cat at a moments notice is crazy...
   / VERY expensive beet juice! #205
This is how my dealer filled the small tires on my SCUT. I did not specifically ask about filling larger tire, but based on his tire filling setup, I believe he filles all tires with this method. He uses another tractor (or forklift) to lift the tire after filling. He mentioned it was the fastest way for them to fill.
   / VERY expensive beet juice! #206
There are several things that can cause the fishkill you described.
One is a total freeze that can allow toxic gasses to build up.
The other is called a "turnover".........That is when the bottom layer of muck, gets too heavy............and you have a 'coinciding' cold front coming in with a lot of rain.
It changes the water so that it basically.............'turns over'............
The most noticeble thing will be that the water will be 'black' on top. I don't think you experianced this because you had surviving fish.............large fish usually die first with oxygen depletion.
yep.. BOD or bio chemical oxygen demand. same deal I mentioned about sugar laden material. real hard on water with aquatic life in it. WAY worse than salt addition. salt addition won't directly kill fish in the amount we are talking about.. same amount of sugar residue materials COULD though, due to secondary effects....
soundguy
   / VERY expensive beet juice! #207
Soundguy - I'm guessing you are suggesting diluting the RV antifreeze that is sold in stores?
Our RV antifreeze is made of gold here in Canada. 4 literes - just over a gallon for $9.49. It is fancy Prestone stuff and is meant to be used straight without dilution. Apparently it is good to -50 Celcius. On the downside it is more expensive that beet juice!
I'll try to see what bulk prices are like. Perhaps the Napa store or a wholesaler has a good deal on WW fluid in bulk as well.
Last year I bought RV antifreeze for $1.79 a gallon at WallyWorld. It was late winter/early spring long after most people worry about winterizing (you either did it by then or have busted up stuff). If you guys that want to load up the tires can wait until Feb., you can probably get a better deal.
Also, The stuff that I got provided burst protection to -50F & not to further dilute. Looking at the DOW PG curve:
(https://dow-answer.custhelp.com/app/answers/detail/a_id/7214/~/propylene-glycols---freeze-points)
So what I have was probably diluted 50/50 already. I did not realize this and did dilute by 50% so I am down to 28% glycol. This means that I have burst protection to - 5F or so (although it will start freezing at approximately 15F). However, the worst that happens is that the stuff freezes in the tire at temps colder than -5F. In western PA it is not common for the temps to get this cold, but does happen occasionally. It's not like the tire will burst as if the anti freeze were in a pipe. It will just turn into a solid. Nonetheless, I'll add more 100% PG to get the burst point down to -20F (30% glycol by weight).
   / VERY expensive beet juice! #208
   / VERY expensive beet juice! #209
Thats nuts...
It does seem crazy, but honestly, when I bought my Koi I paid all of 4 dollars apiece for them. They were only about 3 inches long at that time.
   / VERY expensive beet juice! #210
$4.. thats better:thumbsup: Thats about what i'll pay for fish... Too much to lose, too quickly.
7021 (A55851)
7021 (A55851)
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A58018)
2014 PETERBILT 384...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
Enerpac RCS302 30-Ton Hydraulic Jack, 5" Tall (A59076)
Enerpac RCS302...
JCB Forks and Frame Skid Steer Attachment (A56857)
JCB Forks and...
2019 Freightliner M2 106 AWD Terex Hi-Ranger TC55 55ft Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
