Verticle Motor on Log Splitter
   / Verticle Motor on Log Splitter #1
tnau664
Bronze Member
Piedmont, AL
Massey 231S
Hey shop guys. Need help for a question brought up on the Lawn and Garden forum. I want to add electric start to my splitter so my dear one can help with the firewood. There was an older post that discussed the use of a hydraulic pump on a verticle shaft motor rather than the typical horizontal shaft. Has anyone seen this done? I think simple thoughts, but seems like it should work.
T
   / Verticle Motor on Log Splitter #2
Yeah, lots of splitters have vertical shaft engines. The hydraulic pump couldn't care less about it.
   / Verticle Motor on Log Splitter #3
It will work. I assembled a Barnes 16gpm 2 stage pump tp the bottom of a B-S 11.5 hp motor and has worked fine for 8 years. You'll need the adapter that's used for horizontal engines and the appropriate lovejoy connectors for pump and engine shaft. I used the motor mount plate from the donor riding mower and welded brackets to it which centered the pump adapter to engine.
Thanks for the reply. Now to confiscate a mower. What do you mean by "the adapter that's used for horizontal mowers"? I have the lovejoy connector, but no other adapter.
The idea of using the mounting plate for the motor is great. I'll look at using it with the under hood tank and just put the hood back on to protect it all.
Thanks again
T
   / Verticle Motor on Log Splitter #5
Thanks again
T
Just be sure to mount the tank high enough so the pump cannot be run dry. It only takes a little of that to ruin a pump.
Harry K
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
2018 Vermeer Chipper (A51573)
2018 Vermeer...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
2020 FOR TRANSIT CONECT CARGO VAN (A52577)
2020 FOR TRANSIT...
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
