Oil & Fuel Vertical Shaft Diesel engine?
/ Vertical Shaft Diesel engine? #1
NoPaint
I have a newish Cub Cadet lawn tractor (the cheap $1500-$2000 Loews type's) that I would love to make diesel. It currently has a wonderfully smooth 15hp Kawasaki V-Twin. If it were diesel I think it could do the same job with less HP considering it would have so much more torque. So basically, who made a vertical shaft diesel engine. I would need to buy used so new stuff is probably out of my budget. Thanks guys.
/ Vertical Shaft Diesel engine? #2
Yanmar makes one. I think it is 17HP. I don't. Know the price, but likely a couple thousand. I used to see some of them on eBay, but haven't lately.
You'd probably be better off selling your current unit, and buying a used Kubota or JD diesel garden tractor. There have been several good threads on here about desiel garden tractors.
I have a mid 90's Kubota G1800 with 16HP 3 cyl desiel and a 48" deck ( availible with 48, 54, 60 inch decks). The G1900 is the same with 18HP.
J
/ Vertical Shaft Diesel engine? #3
Yes more torque and lower revs, but therein lies another problem i think. You need high blade speed to actually cut grass, plus enough revs to drive the back wheels at an acceptable speed. So you'd have to solve those problems too. Perhaps its just a matter of changing the pulley sizes and belts but its yet another cost to consider. You'd have to be cutting a lot of grass to justify ditching what you say is a wonderfully smooth donk.
/ Vertical Shaft Diesel engine? #4
I would keep what you have and wear it out, next time buy a better one. That is what I am going to do anyway.
I know you can get small engine diesels that run at 3600 RPM's juts like gas. My Lombardini is a 2800RPM engine but I can crank it up to 3600. Sounds like a vertical shaft diesel won't work.
2015 International WorkStar 7500 T/A Forestry Grapple Truck (A64556)
2015 International...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
KEEVAC SEWAGE VACUUM TANK (A65643)
KEEVAC SEWAGE...
Chevrolet 2500HD (A63689)
Chevrolet 2500HD...
2007 Ford F-150 Pickup Truck, VIN # 1FTRF12247KD16090 (A64194)
2007 Ford F-150...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
