Ventrac/ Steiner forks
   / Ventrac/ Steiner forks #11
DB
These forks are stored off site for the winter where I can't get to them easily for measurements. PM me in the spring and I will get you some information.
   / Ventrac/ Steiner forks #12
BK,
The original frame and forks for the 3 point hitch were rated at 1700 pounds by the manufacturer which is now out of business, but, of course, the front hitch of the Ventrac will not lift that much. I really don't know how much it will lift. However, it has served me well for transporting limbs, brush, platforms, and utility boxes I have designed.
   / Ventrac/ Steiner forks #13
DB
I have recently installed a grapple on my forks. The grapple itself is called "The Thumb" and is available from The Thumb . I designed the mounting bracket--it is not the same as you get when ordering a Thumb.
   / Ventrac/ Steiner forks #14
Jack,
The only times I have had problems with lift capacity are when I've been lifting and transporting large rocks or wet material the excavator lift is usually fine, but there have been times when I would like the bucket angle and dump to have more ability. If you needed to push yourself backwards or pull yourself forwards - there just is not enough force to do that. Most tractors are capable of using the bucket to aid when traction is needed. I just wish the hydro had some more pressure.
BK,
jack, where do you have the thumb plumbed to? I have remotes on the back because i also have 3pt. are you tied into them?
jack, don't worry about the measurements. I have started the forks today with the materials i have here lying around. Thanks Dunebuggy55
   / Ventrac/ Steiner forks #17
DB
You can plumb directly into one of the two rear remotes either by using a pair of long hoses or you can Tee directly into the lines under the seat.
jack,Ok i will look at that, thanks
   / Ventrac/ Steiner forks #19
Got some work done, my barn is unheated so I was working in a balmy 29 degrees all day...still lots to do..
RD looks good, I feel for you working in the cold. I got my frame made today that mounts on the tractor. Also got the fork frame built. Was going to try to make the cylinder roll the forks back and run the thumb up and down but the cylinder stroke to the proportions of the rest of it wont allow me to do this. So i will build the thumb with a seperate cylinder. My forks will be similar to the ones in jacks pics. I will try to get some pics with my phone and post if i can figure it out.
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
TANK MANIFOLD (A58216)
2008 Toyota Rav 4 SUV (A56859)
2008 Toyota Rav 4...
2017 Ford F-350 Flatbed Service Truck (A56858)
2017 Ford F-350...
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
