VENTRAC (Briggs Vanguard) cuts out ...
   / VENTRAC (Briggs Vanguard) cuts out ... #1
Near Cobourg, Ontario
TN75DA
Hi All
Perplexing problem ... my Ventrac 4200, powered by a Briggs Vanguard engine, cuts out without warning, sometimes after 20 minutes, sometimes after two hours ... fuel, fuel pump, safety interlocks don't seem to be the problem ... mystery ... has anyone had this problem with that engine?
HPD
Brighton, Canada
   / VENTRAC (Briggs Vanguard) cuts out ... #2
When it happens, will it restart? Only crank over? Nothing at all? Check for spark and fuel when this happens...
   / VENTRAC (Briggs Vanguard) cuts out ... #3
I know you said fuel seems to not be the issue but I had a similar problem with a B&S Vanguard...check for water in the fuel tank...if there is any water at the bottom of the tank and movement sloshes enough to reach the intake line it will do what you describe...
   / VENTRAC (Briggs Vanguard) cuts out ... #4
Check your oil level, low oil level cutout.
   / VENTRAC (Briggs Vanguard) cuts out ... #5
Primary side wiring with insulation rubbed off against metal frame. Trace that seat cut off switch wire and others, coil primary and such. Use electronics cleaner to spray-out ignition switch. Intermittent problems require patience.
prs
2016 Kenworth T880 Tri-Axle Brenner Fuel Tanker Truck (A51692)
2016 Kenworth T880...
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
1266 (A50490)
1266 (A50490)
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2015 Kubota BX25D (A50123)
2015 Kubota BX25D...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
