VENTRAC (Briggs Vanguard) cuts out ...
   / VENTRAC (Briggs Vanguard) cuts out ... #1
Near Cobourg, Ontario
TN75DA
Hi All
Perplexing problem ... my Ventrac 4200, powered by a Briggs Vanguard engine, cuts out without warning, sometimes after 20 minutes, sometimes after two hours ... fuel, fuel pump, safety interlocks don't seem to be the problem ... mystery ... has anyone had this problem with that engine?
HPD
Brighton, Canada
   / VENTRAC (Briggs Vanguard) cuts out ... #2
When it happens, will it restart? Only crank over? Nothing at all? Check for spark and fuel when this happens...
   / VENTRAC (Briggs Vanguard) cuts out ... #3
I know you said fuel seems to not be the issue but I had a similar problem with a B&S Vanguard...check for water in the fuel tank...if there is any water at the bottom of the tank and movement sloshes enough to reach the intake line it will do what you describe...
   / VENTRAC (Briggs Vanguard) cuts out ... #4
Check your oil level, low oil level cutout.
   / VENTRAC (Briggs Vanguard) cuts out ... #5
Primary side wiring with insulation rubbed off against metal frame. Trace that seat cut off switch wire and others, coil primary and such. Use electronics cleaner to spray-out ignition switch. Intermittent problems require patience.
prs
2017 Vactor RamJet Sewer Jetter Trailer (A51691)
2017 Vactor RamJet...
1994 International 4800 DT 466 Pole/Drill Truck (A52384)
1994 International...
(2) 24" W X 5 1/2L HEAVY DUTY FOLD UP TRAILER RAMP (A51247)
(2) 24" W X 5 1/2L...
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
UNUSED RYOBI 80V HP BRUSHLESS ELECTRIC PUSH MOWER (A51248)
UNUSED RYOBI 80V...
2015 Hooper T/A Trailer w/Mounted Foaming System (A53117)
2015 Hooper T/A...
