Vaporlock revisited
/ Vaporlock revisited #81
George,
It wouldn't pump even with the engine running. I suspect the oil prevented the diaphragm from moving properly. It probably would work now that it's cleaned out, but I expect it would eventually fill up again. I feel more comfortable with the electric pump, but will keep the OE in place in case the electric pump dies at an inopportune time.
I used a standard Bosch 5-pin relay to power the pump, using the oil cooler fan power wire to operate the relay coil, and connected the contacts direcly to the battery (with a fuse, of course).
I agree about OE limitations. I kind of doubt that the engineers at Robin expected the engine to be operated at the angles a PT can routinely handle. I believe the lubrication system is rated to 20 or 25 degrees of slope, but they probably didn't test the fuel pump for hours at those angles. It probably works just fine at the angles a conventional tractor can handle.
One other thing I did while making changes to the fuel system was to add a shutoff valve to the tank outlet. I don't like gravity-feed systems that can't be readily shut off in case of a hose leak. You can spill a lot of fuel while you run around looking for a plug.
The QA cylinder leak appears to have been due to the shaft seal coming adrift from it's seat inside the cylinder. When I removed the end cap, the seal ring was moving with the shaft, not staying in the cap. I cleaned and inspected everything under magnification, and saw no damage or any indication of why it came loose /forums/images/graemlins/confused.gif, so I reseated the seal and reassembled. I've operated it several dozen times so far with no leakage, but I'll be watching it closely for a while.
Gravy
/ Vaporlock revisited #82
<font color="blue"> I kind of doubt that the engineers at Robin expected the engine to be operated at the angles a PT can routinely handle. </font>
It would be interesting to find out if that is indeed the case. It is my understanding that small engine manufacturers typically review customer engineering data before approving their engines for sale to OEMs. Supposedly, this is so they don't get stuck covering warranty claims for damages that are caused by improper application of their products. For example, I was told (I forget by whom) that Kohler had to approve the PT 'tank' muffler since it would have a direct bearing on engine life, and thus Kohler's potential liability for warranty claims. I wonder if Robin has similar requirements?
/ Vaporlock revisited #83
"I used a standard Bosch 5-pin relay to power the pump, using the oil cooler fan power wire to operate the relay coil, and connected the contacts direcly to the battery (with a fuse, of course)."
I'm not really up on electric fuel pumps but I have a question. On my tractor the cooling fan has power with the ign. switch in the on position even if the engine is not running, and for some reason my key sometimes ends up in that position after I shut down. Put some extra hours on the clock also. Anyway, if that occurs, is the fuel pump going to keep pumping fuel ?
/ Vaporlock revisited #84
If there is no fuel pressure regulator, it will keep running as long as it has voltage. You should be able to hear or feel it running.
/ Vaporlock revisited #85
The pump will be powered, and will draw current, but no fuel will actually flow unless the carb float needle leaks. If you leave the key on, and have a leak, the pump could empty the tank pretty quickly. Of course, since the tank is higher than the carb, a leak could empty the tank even without a fuel pump. It would just take longer.The pump I'm using maintains 4psi and shows no signs of flooding the carb. Also, leaving the key on overnight would likely run the battery flat.
The ideal setup for an electric fuel pump would require a relay that senses ignition pulses and only energizes the pump with the engine running. I'm not sure that any such automotive relays I've used would be compatible with the Robin ignition system. I believe Kohler has a line of fuel-injected engines that might use a relay that could be adapted.
Having worked on plenty of cars (from MG's to Nissans & Hondas to hotrods) over the years with exactly the sort of setup that I'm using, I'm comfortable with it as-is. Your results may vary...
Gravy /forums/images/graemlins/tongue.gif
/ Vaporlock revisited #86
Gravy, if you folks want want fuel pump to run only when engine is running consider the following:
1. Tee off one of your engine oil pressure sender switch. If there is no oil pressure sender tap into a hydraulic pressure line and plumb in a pressure switch that closes when seeing hyd pressure. Engine oil is prefered because of much lower pressure and a cheaper switch to buy. These switches are common to hour meters. Another source is old Chevy Vega oil sender sw that used oil pressure to trigger the elec fuel pump and oil light in one switch. Bottom line, what you want is a switch that closes to gnd (single wire preferred) when it sees engine oil or hyd pressure. Most hyd systems run a pressure between 2,000 & 2,500 psi so you DON"t want use an auto oil sender sw here. Also, most automotive pressure switches go open, (to put out light) and not close when they see pressure. You want just the opposite here.
2. The Bosch relay has two terminals (85&86) for the pull in coil, one for B+ (sw high) and the other for gnd (sw low). Hook the hi one to ign on and the low one to the pressure sending unit. Terminals 85&86 are not polarity sensitive unless a anti-spike diode inside is wired aross these two. If you don't know about diode make 85 B+ & 86 gnd. Number 30 should be B+ in and 87 goes to load (pump).
3. With this setup it will take both ign on and engine running to run fuel pump. The down side of this setup is that the fuel pump will not run until engine oil light goes out. However, this should not be a concern since you have gravity flow to your carb at all times.
hope this helps,
/ Vaporlock revisited #87
George,
Jeez, I'm embarassed - CRS strikes again! I've done that exact circuit before, AND my engine has an unused oil pressure switch.
A few years away from the auto repair business, and I'm practically a drooling moron. I hate to admit it, but my calibrated eyeball isn't what it used to be, either. I used to be able to grab the right wrench at least 95% of the time without even thinking about it. Somehow, on this project I grabbed the wrong wrench at least 3 times. I'm beginning to feel like a candidate for the Home for Bewildered Old Mechanics.
I will be making that circuit change.
Thanks,
Dave
/ Vaporlock revisited #88
Since there is some interest in installing electric fuel pumps on PTs, I thought I would mention a type I've used a couple times in the past.
Stewart Warner makes them. They are a line of fuel pumps that, as far as I know, do not draw power when they are not delivering fuel. They are piston pumps with built in pressure regulators. In operation, they make a clicking sound (as opposed to the whirring of motor driven pumps). If no fuel is being consumed, the clicking stops as soon as the fuel line is brought up to pressure.
I've used a couple of these pumps in different applications, and if I remember correctly, they are entirely electro mechanical; if the pump isn't clicking, no power is being consumed.
The pumps are in the model number range of 82050 to 82057, and perhaps higher. They are available with 4, 5, and 7 PSI pressure settings, that I know of. They are not adjustable, so you have to buy the right one up front.
I don't think they are cheap, though.
/ Vaporlock revisited #89
Gravy, there is a good chance that the second oil pressure sending unit was intended for an hour meter.
Let's hope it's a pressure gives gnd switch and not open sending unit.
Hey, I hear you on the fading memory business. I too have trouble coming up with the proper wrench size with each call.
On the plus side, some things are best flushed away ASAP.
It's like clearing up the temporary folder!!
cheers,
SnowRidge,
The diaphragm pump that you mention was the one I intended to install but my parts guy recommended the "electronic" pump that I ended up putting on. It's working fine.
Attached is a photo of the angle I am trying on the Supertrap. I worked the PT for a couple of hours Saturday and had no indication of VL. However, an hour or two of stumpgrinding will be a more accurate test. A couple of hours of brushhogging when the temps reach 90 will be the ultimate test.
Please limit comments on my welding ability to "constructive criticism". I did this mod quickly and will grind and fill to make it look nice once I've determined that my VL problem is gone. IF it solves my problem.
And I should be receiving the fiberglass insulation any day now.
Phil
Another photo on the Supertrap angle.
Remember, be easy on the looks of the weld.
Phil
Ok, tweaking the Supertrap out didn't work either. I worked the machine pretty hard last weekend. It never vaporlocked, but it was pretty cool outside. However, when I turned it off to refill the fuel tank, I could see bubbles coming up from the fuel tank elbow. It got worse after I shut the engine off too. Kept going for awhile... confirms that it wasn't junk in the elbow or in the carb bowl. Simply too much heat too close to the fuel hose.
I'm going to try tracdoc's suggestion (although not exactly) and wrap the fuel line with a few layers of the fiberglass/foil insulating stuff that I got. I have plenty so I'll put a layer inside the tub too, on the exhaust side.
Should've just ordered the stuff tracdoc recommended in the first place. Same price as the fuel pump and maybe it'd be fixed by now.
Sure wish he or another PT'er would find someone to make custom headers for these, at maybe $49.95 plus $10 shipping (as long as I'm dreaming I might as well make it good!!).
Phil
/ Vaporlock revisited #93
</font><font color="blue" class="small">( Sure wish he or another PT'er would find someone to make custom headers for these, at maybe $49.95 plus $10 shipping (as long as I'm dreaming I might as well make it good!!). )</font>
Oh, you are a mind reader, Phil. I was thinking of popping off my header, and taking it over to my friends at A&E Racecars in South Boston, VA to see what they could do in terms of a custom header. Your post pushed me over the edge, so I called them today. It will have to wait since they are up to their a**es in alligators trying to get stuff finished for this racing season. I'll have to check back in a few weeks to see if they have the time for this. Remember, I am just going to get a price quote, only a quote, nothing else, just a quote /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Vaporlock revisited #94
I've checked into the Robin side mount exhaust system. (See pages 42 and 43 of the parts manual at: http://www.robinamerica.com/engines/manuals/parts/EH63_EH64_EH65_EH72_prt.pdf ). My local dealers will sell the whole system P/N 92630004 for about $120+S&H. I'm guessing that it will fit with the addition of a spacer between the manifold and the muffler. I've got several other projects that come first, so it will probably be a while before I get around to ordering one.
Gravy
I got a lot of work done this weekend. The PT never once died from VL. However a couple of times when I stopped it for a break I noticed bubbles coming up into the fuel tank. The little bit of insulation I installed between the fuel hose and the exhaust-side of the tub helped and indicates the problem indeed lies there.
I discovered something else too: the run-on and/or backfire when shutting down was greatly reduced if not entirely eliminated. I'm guessing that the boiling fuel was making the engine run hotter because of the lean condition.
My next tentative plan is to reverse the exhaust manifold/muffler. That is, take it off and reinstall it so that it exhausts out the right side of the PT. I haven't tried it, but it seems like it'd bolt right up that way, with a cutout in the engine cover on the right side to match the one on the left. Fortunately I'll be able to completely try it before cutting anything.
That would move the hot exhaust to the side opposite the gas lines. Seems to make more sense than trying to insulate gas hoses from nearby exhaust heat. The SuperTrap would be pointing up which would make it less vulnerable to bumping into brush.
Am I overlooking anything here?
Phil
/ Vaporlock revisited #96
</font><font color="blue" class="small">( My next tentative plan is to reverse the exhaust manifold/muffler. That is, take it off and reinstall it so that it exhausts out the right side of the PT. )</font>
Hmmm.....now, why didn't I thunk of dat?
It certainly sounds like a reasonable choice. I'm sure you'll find out toute suite if the spacing between the exhaust ports is symmetrical once you remove the header and try to flip it around the other direction. If that works, I would consider that arrangement for any future custom work, too.
BTW, I did note that the gap between the forward edge of the header pipe and the steel firewall protecting the battery is pretty narrow. This might become an issue in fitting standard rounded exhaust pipes.
Gravy, I'm having trouble with that link....seems dead, and I can't access it directly either right now. Maybe Robin's website is the problem...I'll try later.
/ Vaporlock revisited #97
Phil,
On the 180 the short exhaust pipe connected to the manifold is longer off one cylinder than the other so reversing on the 180 would require some modification. Hopefully yours is different though. /forums/images/graemlins/smile.gif
Thanks, Bill.
I'll be checking it this weekend. Originally I was considering slicing the stock "muffler" and welding it back together 180 degrees different -- with the outlet pointing up instead of down. Then it occurred to me that maybe I could just reverse the entire assembly, as I mentioned.
That manifold comes off so easily that it'll be quick to check. If it won't fit, as apparently the 18hp won't, I'll rethink it all. If it's as you say on yours, it may still be easier to cut/reweld one of those small pipes rather than the muffler but alignment would be critical.
S'posed to rain into Saturday morning. Perfect time to work on the PT as I won't be able to use it until later in the weekend.
Phil
Dang it, Bill.
Mine's offset too.
That means I'd have to chop off the pipes and reweld in the opposite positions.
Not as easy as I'd hoped. But not too difficult either.
Knowing me, I'll put it on the back burner until I vaporlock again.
Phil
/ Vaporlock revisited #100
Phil,
FWIW,
After installing the second electric fuel pump (the first one was from my junk box and died after an hour), I worked full throttle at heavy digging for 5 or 6 hours with no vapor lock or fuel starvation problems. Since an electric pump didn't solve your problem, it appears that our problems may have different root causes.
Life has gotten interesting for the last week or so, so I haven't gotten around to actually ordering , much less installing the factory exhaust system. It looks like I won't get to do that until at least next weekend. However, rather than rearranging your exhaust system, you may want to try relocating your fuel pump and hoses. The fuel pump and bracket can be unbolted from the engine and moved to wherever you like, and the hoses can be run around the other side of the engine compartment.
Also, if you haven't tried it, run a hose straight from the electric fuel pump to the carburetor. The mechanical pump could possibly be restricting the flow from the electric pump.
Good luck!
Gravy
