Vanguard fireplace inserts
/ Vanguard fireplace inserts #1
Sigarms
Super Star Member
Mid north west in the state of N.C
F3080
Does anyone have a Vanguard ventless fireplace?
Curious as to how you like them? Anything bad to say?
Since I have an existing fireplace not in use, thought I'd go this route for back up heat (primary heat being a heat pump).
Thks!
/ Vanguard fireplace inserts #2
I have a Vanguard vent free fireplace in my basement. We have a regular fireplace w/chimney on the first floor and the house foundation is "bumped out" in the area under it creating an "alcove" so I inserted the fireplace insert there. It's great - makes the basement real cozy in the winter.
Just make sure you have enough free movement of air to support the burning and dissipate the water vapor.
Since you have a regular fireplace where you're going to put the insert, though - why not go with a direct-vent unit instead of a vent-free?
WVBill
WVBill
I'll be installing an variable speed air handler with a heat pump for primary heat. The fan will be running 24/7 for air movment, even when I'm using the fireplace.
Going vent free due to cost and PITA factor for venting. Numbers wise, I could heat the first floor with that R410A heat pump and strip heat alone, however, I just like the idea of having gas for back up heat if I want it (millivolt system as well on the fireplace). Vent free fireplace is the easiest, cheapest way to go. I probably won't end up running that fireplace more than 15 days out of the year.
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
2008 HINO 268 4X2 S/A ARMORED TRUCK (A59910)
2008 HINO 268 4X2...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
2860 (A56857)
2860 (A56857)
UNUSED KJ 45'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 45'X25'...
