Valvoline Premium Blue Extreme vs. Shell Rotella T6
   / Valvoline Premium Blue Extreme vs. Shell Rotella T6 #1
antlers125
Elkton,Md
LS J2023h
   / Valvoline Premium Blue Extreme vs. Shell Rotella T6 #2
I think either one is a solid choice.
I will say I see a ton more threads about people using Rotella. Not sure if that really means anything though.
   / Valvoline Premium Blue Extreme vs. Shell Rotella T6 #3
I think it is mainly because Rotella is a very good oil and is widely distributed among retail outlets which makes it so readily available everywhere.
I agree the Valvolene oil would be very good also. I see no advantage of one over the other.
   / Valvoline Premium Blue Extreme vs. Shell Rotella T6 #4
imho the only difference would be in the additive package of each oil. can't help with you on that, but probably an easy search.
can't go wrong w/either given viscosity range & diesel rating ... how does cost between the 2 come into play?
rest easy w/either......
   / Valvoline Premium Blue Extreme vs. Shell Rotella T6 #5
The most important difference that people are not covering is the color of the bottle. Which one is going to match your tractor the best, a light blue with more white or darker blue with more blue label. You need to accessorize correctly because there is nothing more embarrassing than having the wrong colors when out and about.
In all seriousness, get the one that is cheaper/easier to get/sold at your favorite store/sold by the cashier you have a crush on/??? Either one is going to work great for you, if you were running a several thousand horsepower engine or something else very very very extreme the additive package might matter.
   / Valvoline Premium Blue Extreme vs. Shell Rotella T6 #6
or tractor pull..... like your sense of humor in these heated times. it does put things in perspective. now about that several k hp tractor, what color is that? all in good fun :cool:
   / Valvoline Premium Blue Extreme vs. Shell Rotella T6 #7
I don't really see much of a difference between the two. I use T6 simply because I need about 10 quarts and I can order it from Walmart with free 2 day shipping for something like $22/gallon. One of the local autoparts stores (that just got bought out by Oreilly) sells the Extreme blue but it works about to be about $20 for 3 gallons and I have to go pick it up.
   / Valvoline Premium Blue Extreme vs. Shell Rotella T6 #8
X2 on both paragraphs. :laughing:
   / Valvoline Premium Blue Extreme vs. Shell Rotella T6 #9
I tried premium blue extreme once, good oil. But the downside is that its a diesel only oil, T6 can be run in gas engines too. Everything except my truck runs T6.
   / Valvoline Premium Blue Extreme vs. Shell Rotella T6 #10
LMAO......comment category: Priceless.
Unused 2025 LandHonor LDH-KN16 Mini Excavator (A52377)
Unused 2025...
1990 John Deere 2955 Cab Tractor (A55218)
1990 John Deere...
2021 CATERPILLAR CB2.7 DBL DRUM ROLLER (A52705)
2021 CATERPILLAR...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
