Valve stems facing wrong way?
/ Valve stems facing wrong way? #21
Someone stole my rear valve stems.:mad:
No, wait, their on the inside.:p
/ Valve stems facing wrong way? #23
I just took delivery on a used L3130, and noticed the rears have their valve stems on the inside, too. I don't think the wheels are reversible, but haven't looked into it yet. Filled tires, so changing them might be a task.
I'll be $$ to donuts yours are reversible.
My rears were "innies" until I had the local Kubota shop reverse my rears to make the the widest possible. Then they became "outies"; much more convenient! My fronts were already outies, so no change there needed. Plus, the manual does not recommend reversing them due to the possibiity of breaking the hubs (my L4330 is a 4x4).
/ Valve stems facing wrong way? #24
FTG-05... You're right, I think. In looking at them some more, I noticed that reversing them would A) make the track much wider, and B) place the valve stems on the outside. FWIW, the fronts, with outside valves, have steel guards around them. I can't see myself jockeying a 500+ lb tire around, so I guess I will just leave them alone for now.
/ Valve stems facing wrong way? #25
What tires are on it? Most of the 30 series front rims are not reversible. The rears are. My front R4's have the valves stems out and have guards even though the 2 rims are slightly different designs.
/ Valve stems facing wrong way? #26
On my L3400 they are reversible, however Kubota says in the owners manual not to reverse them, for whatever reason.
Sean
/ Valve stems facing wrong way? #28
Cheap axles.:eek:
Wait until you pay to repair one. I reversed mine to fit on a trailer;even though it says not to. Well the front loader fully loaded with a Ford van chained to the bucket for loading onto a trailer made a very expensive ,"pop". The result was very expensive to repair, broken bearing,ruined gears,even part of the cast iron hub. Leverage on the axle changes. Take the tires off and mount them so the valve stem is where you want it.
Bobcat NB160 (A64127)
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
JOHN DEERE 6105E TRACTOR (A64277)
JOHN DEERE 6105E...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
Bale Ring (A66408)
Bale Ring (A66408)
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
