Samandothers
Platinum Member
I was running the Bush Hog and something hit the rear tire valve stem. The stem was cocked to the side and the tire was leaking air and fluid. I am not sure how to repair so I put air in the tire so I could load the tractor on the trailer. I put some wood blocks under the subframe to hold the tractor up so the rim will not settle on the tire. I notice it appears to be two pieces and has a collar that screws down against are toward the rim.
Are these stems pushed in? Is this something that can be repaired with the wheel on the tactor? I plan to take to dealer for repair but wondered what might be involved.
Thanks for any input.
