Backhoe valve seals leaking
/ valve seals leaking #1
coxey2
kubota b2150
My LW6 outrigger wouldn'nt go down. I traced the problem to the valve under the outrigger lever. When I removed the cup on the bottom of the valve lever ( not sure what its called) a spring and bolt and white ring and chewed up oring came out with it. Where can I find the white plastic ring and oring?? thanks in advance. :)
/ valve seals leaking #2
Affordable equipment Texas,,,,,,look in the Chinese tractor forum
2021 John Deere 1023E Tractor Loader (A63116)
2021 John Deere...
PALLET OF SPRINKLERS & BLACK HOSE (A63745)
PALLET OF...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2023 Deere 325G (A60462)
2023 Deere 325G...
2024 Bobcat T740 Track Loader (A63109)
2024 Bobcat T740...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63118)
2023 Kubota U48-5...
