Backhoe valve seals leaking
/ valve seals leaking #1
coxey2
Member
kubota b2150
My LW6 outrigger wouldn'nt go down. I traced the problem to the valve under the outrigger lever. When I removed the cup on the bottom of the valve lever ( not sure what its called) a spring and bolt and white ring and chewed up oring came out with it. Where can I find the white plastic ring and oring?? thanks in advance. :)
/ valve seals leaking #2
Affordable equipment Texas,,,,,,look in the Chinese tractor forum
Case Titan 3530 (A61307)
Case Titan 3530...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
KUBOTA MX5800 TRACTOR (A62130)
KUBOTA MX5800...
2023 Deere 325G (A60462)
2023 Deere 325G...
2011 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2011 DRAGON 150...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
