Loader valve leaking
/ valve leaking #1
huckerpaxton
kubota b7800
the valve on my loader is blowing out the front on somr type of relief or blow out valve,any one know why?
/ valve leaking #2
The fluid in the hyd system does not exit anywhere except into the tank. If you see fluid, you have a leak of some kind.
Some relief valves leak out the adjusting cap.
If it is leaking anywhere else, there is something loose, or there is a defect in a hose, a fitting, spool o-rings, or split valve, etc.
Take a pic and point to the area if possible.
/ valve leaking #3
About your valve body if its gimballed valve set its
time to think about getting new valve body.
If your set up is a 2 spool valve unit you have blown o-rings
and spool seals. If its relatively new valve you can have someone replace the spool seals and O rings; if its an old spool valve its time to scrap it and buy a new one.
2017 CATERPILLAR 335FL CR EXCAVATOR (A65056)
2017 CATERPILLAR...
FIRD MIXER TRUCK (INOPERABLE) (A67714)
FIRD MIXER TRUCK...
2020 HAULOTTE 3522A TOWABLE ELECTRIC BOOM LIFT (A65056)
2020 HAULOTTE...
Unused 2023 Hustler LM260 Swiftblade Tractor Loader Attachment (A66734)
Unused 2023...
Bigfoot with Bottle Metal Decorative Yard Art (A66738)
Bigfoot with...
2086 (A65055)
2086 (A65055)
