Loader valve leaking
   / valve leaking #1
huckerpaxton
kubota b7800
the valve on my loader is blowing out the front on somr type of relief or blow out valve,any one know why?
   / valve leaking #2
The fluid in the hyd system does not exit anywhere except into the tank. If you see fluid, you have a leak of some kind.
Some relief valves leak out the adjusting cap.
If it is leaking anywhere else, there is something loose, or there is a defect in a hose, a fitting, spool o-rings, or split valve, etc.
Take a pic and point to the area if possible.
   / valve leaking #3
About your valve body if its gimballed valve set its
time to think about getting new valve body.
If your set up is a 2 spool valve unit you have blown o-rings
and spool seals. If its relatively new valve you can have someone replace the spool seals and O rings; if its an old spool valve its time to scrap it and buy a new one.
JOHN DEERE TD100 10' TANDEM DISC HARROW (A51243)
JOHN DEERE TD100...
UNUSED JCT QUICK ATTACH 74" VIBRATORY ROLLER (A51244)
UNUSED JCT QUICK...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
`2021 CATERPILLAR 246D3 WHEELED SKID STEER (A51242)
`2021 CATERPILLAR...
Skid steer auger plate (A50322)
Skid steer auger...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
