valve detent kit
/ valve detent kit #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I am trying to put a detent kit on one of the spools of my Baileynet valve. below is the link to the only documentation I have. When I remove the cover off the back side of the spool there is a big screw holding the spring. Do I need to compress that spring before I can get the screw loose?
/ valve detent kit #2
No link...Not that familiar with Baily's valve yet.
/ valve detent kit
Let's see if this works. Here is the added page that Bailey sent me. I am trying to get screw 79.09.04 off. This is one of those large slotted screws about 4x larger than your screw driver. I was wondering if I need to compress the spring 79.09.03 in order to get the screw loose. The detent kit consist of a new cap and screw.
/ valve detent kit
It keeps the valve from returning to neutral. I will be running a post driver off the third spool so I need it to stay open. The other option is to use a bungee cord to hold the valve open but for $20 I though it would be easier to go this route. If I ever want it to spring center again I can replace the spring.
2021 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2021 Chevrolet...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
11.2-24 Tires - Set of 4 (A68134)
11.2-24 Tires -...
2019 CATERPILLER 249D SKID STEER (A65056)
2019 CATERPILLER...
ALLMAND  MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
