Valve Adjustment
/ Valve Adjustment #1
FGATORFAN
Jacksonville,FL
YM2000BD
I have a YM2000BD and I am planning on adjusting the valves and I need a little info. What type of gasket does the valve cover use? Is it reusable? And if not where can I purchase one? I have been watching and reading post for awile and I decided it was time to get involved. Thanks for all of your valuable info.
Reid
/ Valve Adjustment #3
The models I have worked on had an O-ring for a gasket. I used the old one. I cleaned it off, trying not to disturb it in it's groove on the valve cover. Then I apply a very thin coat of silicone gasket maker. I have had very good results. Of course it is aways better to replace it if you have a new one.
From another Reed
/ Valve Adjustment #4
Do you want to adjust the valves to learn how to do it or is your engine giving you an indication it needs it?
/ Valve Adjustment
I have 660 hours on it and just thought it was about time. I have not noticed any signs that the valves need adjusting.
Reid
/ Valve Adjustment #6
A little P.M. does not hurt nobody if it runs it get tight or lose. valve adj.that is
Don Wynn
/ Valve Adjustment #7
It probubly wont need an adjustment for a few thousand hours or more. But if you have the time and want to sharpen your skills then have fun /w3tcompact/icons/grin.gif
/ Valve Adjustment #8
The tricky thing about adjusting the valves is that you have to rotate the engine to get each one to its loosest point. Remember that a diesel can and will start up by simply rotating the crank. So be careful.
I set mine in the time-honored fashion....checking or setting the intake valve when that cylinder's exhaust valve is just beginning to open and the exhaust valve when the intake is just closing. This avoids cam profile overlap as well as any silencing ramps and automatically puts you at the point of maximum clearance. It also avoids the need to find the compression stroke. Every 4 stroke engine I've ever seen can be set using this method.
My feeling is that any engine new to you should have the valves lash checked. If it is only a thou or two off, then resist the urge to get it perfect....just let it be. Do set the compression release clearance at the same time and lube that mechanism. Check it again in a decade or so.....
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
IRanch High-End Tricycle (A64119)
IRanch High-End...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
KMC 6-36 (A64119)
KMC 6-36 (A64119)
