value of a 1820D
   / value of a 1820D #1
howlinwolf
Tractor has about 800 hrs good rubber 4x4 and a new koyker loader. I am looking to buy it but I am relatively new as far as looking for a Yanmar in the market place. I have five acres with mostly dirt work and sickle mower and of course winter time snow removel, will this tractor do the job? thanks all
   / value of a 1820D #2
I have a 2020D with Koyker loader that I have $7500 in it. I can easily work 10 acres with it. Maintain drive and mow pasture. I do not know about snow. It should do well I personally would not have a tractor that is not 4x4. It can handle larger work than the 2 wheel and is more stable. I love the powershift on the coll um.
   / value of a 1820D
Hey thanks Normmm, So an 1820D with new koyker FEL in great shape should be around $7,000. I will look for one in that range then. Thanks
   / value of a 1820D
Hieght from the ground to the top of the smoke stack. Does anyone know the distance. I will store it in a heated garage if it is under 7ft. which will help greatly for snow removel. thanks
   / value of a 1820D #5
1820D ,4WD ,21.5HP,Yrs. made 82-83, weight 2314lbs., lenght 104",width 45", height 70"
   / value of a 1820D #6
Are you buying from a dealer ?? If so,Have you checked out the dealer ?? I wouldn't worry about the height on that tractor going through a 7' opening. . I have a 3110 which is a larger tractor. With the ROPS in the up position I can just squeeze into my 7' opening
   / value of a 1820D
Kenmac,Stan Hoye is the guy that has the tractor. He seems really nice and easy to work with
   / value of a 1820D #8
That would be a place to buy. Just would hate to see you buy or stuck from some road side tractor / car sales place ( if you know what I mean )?
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
