value of a 1820D
   / value of a 1820D #1
howlinwolf
Tractor has about 800 hrs good rubber 4x4 and a new koyker loader. I am looking to buy it but I am relatively new as far as looking for a Yanmar in the market place. I have five acres with mostly dirt work and sickle mower and of course winter time snow removel, will this tractor do the job? thanks all
   / value of a 1820D #2
I have a 2020D with Koyker loader that I have $7500 in it. I can easily work 10 acres with it. Maintain drive and mow pasture. I do not know about snow. It should do well I personally would not have a tractor that is not 4x4. It can handle larger work than the 2 wheel and is more stable. I love the powershift on the coll um.
   / value of a 1820D
Hey thanks Normmm, So an 1820D with new koyker FEL in great shape should be around $7,000. I will look for one in that range then. Thanks
   / value of a 1820D
Hieght from the ground to the top of the smoke stack. Does anyone know the distance. I will store it in a heated garage if it is under 7ft. which will help greatly for snow removel. thanks
   / value of a 1820D #5
1820D ,4WD ,21.5HP,Yrs. made 82-83, weight 2314lbs., lenght 104",width 45", height 70"
   / value of a 1820D #6
Are you buying from a dealer ?? If so,Have you checked out the dealer ?? I wouldn't worry about the height on that tractor going through a 7' opening. . I have a 3110 which is a larger tractor. With the ROPS in the up position I can just squeeze into my 7' opening
   / value of a 1820D
Kenmac,Stan Hoye is the guy that has the tractor. He seems really nice and easy to work with
   / value of a 1820D #8
That would be a place to buy. Just would hate to see you buy or stuck from some road side tractor / car sales place ( if you know what I mean )?
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2019 CATERPILLAR 926M WHEEL LOADER (A52705)
2019 CATERPILLAR...
Box Truck Hydraulic Tuck-Away Lift Gate (A52377)
Box Truck...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A53473)
2022 New Holland...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
Deer Gates (A53424)
Deer Gates (A53424)
