value leader EF155 flail mower rotor replacement.
   / value leader EF155 flail mower rotor replacement.
pics of bearing housing after drilling for grease fitting 20190502_205426.jpg20190502_205446.jpg20190502_205428.jpg
   / value leader EF155 flail mower rotor replacement. #22
Hopefully it works out ok. I can relate to the making chips thing, having a lathe and mill along with all the other metal working "stuff" makes time spent building or repairing a pleasure instead of a chore. Also in my case, being retired takes the pressure off.
after some delay I finally finished the mower. the rotor repair came out much better than expected. no vibraion at all
   / value leader EF155 flail mower rotor replacement. #24
Nice work. I am glad you were able to save it.
just and Update, two years later, mower is still working fine, no damage to the grease zerk that is mounted in the bearing housing inside the mower on the rotor , I did hard face the grass blades the last time I changed the blades out. I used a powder hard facing torch, blades blades have lasted about 4 times longer than usual. I know hardfacing blades is not recommended there is risk of the hard facing chipping and causing injury or property damage,
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58017)
2017 FREIGHTLINER...
NEW Woods 6ft Finish Mower (A56436)
NEW Woods 6ft...
Husqvarna FS 7000 D Walk-Behind Concrete Floor Saw (A55973)
Husqvarna FS 7000...
2019 FORD E350 16FT BOX TRUCK (A58018)
2019 FORD E350...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
