Vacuum Pump Needed
/ Vacuum Pump Needed #21
Hey,
I vote for a foot valve also!
Now here is an idea---
Plumbing supply houses will have a 4" ABS back flow valve, also known as a sewage back water valve.
That is in the reasonable price range and you then would add a 4" ABS (male or female) pipe thread adaptor.
The unit is all ABS with a flapper valve that will retain your prime, so you will prime only once.
I would fashion a 'cage' of some sort to keep out trash otherwise the smallest twig could hold the flap open.
Probable price $60.00 or so.
Call it 'The poor man's foot Valve"
I bet a proper brass foot valve would run over $300., heck a 1.5" is $50,!
Good luck!, and hey it WILL work.
I once did just that, but using a 2" backflow valve.
Bob
/ Vacuum Pump Needed #22
Good idea on the check valve. both will work fine.. and the check valve is waaaaaay cheaper!
Soundguy
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
John Deere 412R (A63688)
John Deere 412R...
Landhonor Quick Attach Seeder (A66285)
Landhonor Quick...
2019 FREIGHTLINER M2 4X2 S/A 26FT BOX TRUCK (A59914)
2019 FREIGHTLINER...
