Vaalkameel
/ Vaalkameel #1
smitan
Pretoria
SAME Minitauro
Hi, I recently bought a SAME Minitauro that I need to recondition. I need a workshop manual.
/ Vaalkameel #6
Welcome from VA
/ Vaalkameel #7
I have a workshop manual and ops manual if you're still looking.
/ Vaalkameel #8
Welcome to the forum.
It looks like you might have found your answer. :)
I'm going to move this thread on over to the projects section. Best of luck!
/ Vaalkameel #9
Good day. We just bought a SAME Minitauro 60.We bought it as a Falcon 50, but after checking the engine no and bore we realised its a Mintauro 60. We (my son 19, the farmer and I, an aircraft mechanic) bought it with the engine partially disassembled. We realised some of the piston rings were stuck due to being fitted upside down. After a whole day of cleaning honing and burs removal we assembled it and it runs good. When hot the oil light flashes at idle so the oil pressure is a bit low. Looks like we have to fit new big end and main bearings.
We do have a lot of questions, like why are there 2 levers fort 3 point lift? Lift and draft control below the steering and left of the seat a second spring loaded lever that also raise the lift?
If any one can help with a operators and workshop manual, it would be great!
/ Vaalkameel #10
G'day Mate and welcome to TBN from Downunder.
Enjoy the site... from wherever in the world you are.
Some pictures of the levers will go a long way in helping us help you and your son.
Onan 6500 Generator (A66408)
Onan 6500...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2011 Ford F250 Lariat Super Duty (A66408)
2011 Ford F250...
2018 KMC 4505 (A64126)
