Buying Advice v-blades for toolcats
/ v-blades for toolcats #1
eides15
Holmen, Wisconsin
Bobcat Toolcat
Has anyone used a v-blades that is just hydrolicly controlled only. Bobcats v-blade is a eletric over hydrolic and that seems lodgical but I got some pricing from a different company that does all the blade combinations through hydrolics only. Seems like a well built attachment 1190# compared to 770# of bobcats. Also is the weight getting to be a concern. From the reading that I found it looks like the rated lift capacity is 1500# at full height and the tipping capacity would be double that. Is this true? I want to get the v-blade but am I over thinking things when the straight blade would be fine. I guess who has a v-blade and do you like? So give your opinions on the matter. Thanks
/ v-blades for toolcats #2
Can't help with snow blades, but it will handle the weight.
My 5610F can lift this 1800 pound deck to full curl and full height.
Measured just over 3000 pounds at the attachment plate, the back wheels didn't come off the ground.
Do you have a 5600?
/ v-blades for toolcats #3
We just bought a 5600 and got a V-blade with it. We havent used it yet so I can't comment to how well it moves snow. Weight is not an issue at all it lifts it easy with no problems. The construction is solid and we talked to several people who had used one before and they like them a lot.
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
Vicsec 30in. Grading Bucket Mini Excavator Attachment (A61572)
Vicsec 30in...
Caterpillar 302.5C Mini Excavator (A61572)
Caterpillar 302.5C...
2021 Frontier GM4060E Mower (A64047)
2021 Frontier...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
