V belt size????
   / V belt size???? #1
watersteps
David Bradley 917.5121 Terramite T5C
Hello,
I just purchased a David Bradley 917.575121 with a Wisconsin ACN engine. The tractor has 3 belts which I would like to replace at sometime. the belts are 530H, 529H and 7843MI per the manual. Can anyone tell me what size belts I need to replace these belts??
   / V belt size???? #2
Hello,
No worries,
All V belts are metric so its not a problem find a V belt reseller like NAPA that can measure the belts for you using a V belt gauge and they will provide you the proper new V belts quickly.:thumbsup::):drool:
   / V belt size????
The problem is the belt I have is a 1/2 inch belt this pulley takes a 5/8 belt.
I have been using it and it works fine but, I have decided to replace this Wisconsin ACN with a Briggs or Tecumseh with a recoil starter.
I will be selling the Wisconsin or trading it for a 8 hp Briggs if possible.
Thanks for the info.
   / V belt size???? #4
On your V belt spend the extra money a get outdoor or equipment rated belts. They are meant to have a back idler so they bend and they are fabric covered. Industrial belts are meant to run inline and around larger sheaves.
Craig Clayton
   / V belt size????
Thank you, good advice.
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
2015 ISUZU NRR 20FT BOX TRUCK (A51222)
2015 ISUZU NRR...
Quick Attach Pallet Forks (A47384)
Quick Attach...
