UTV's and ATV's general discussion.
   / UTV's and ATV's general discussion. #491
Do you know Matt Scrunton (sp) he is up your way and was into these
I have not heard the name. I'm afraid to go look. If I come home with any more gadgets, I'll probably end up single.
   / UTV's and ATV's general discussion. #493
nice to see you admit the facts
Golly, you have a hard time with reading comprehension as I have never denied fact.
However I will challenge any who makes unfounded claims such as, "Eggs are yucky" without any further details such as, what kind of egg and how was it prepared?
   / UTV's and ATV's general discussion. #494
we got ask to let this go...
post 462 imply you denied it.... I get your point, not all battery or vehicle are made equal, but my point is simply all battery gets affected by the cold its physics, you simply seem to deny that until you didn't.
Do one need to eat sh%t to know how sh%t taste like? but SH%t from what kind of animal ? humans, cow, horse, dogs, or cat ? I agree some SH%t smell worse then others but sh%t is Sh%t.
If one need to try everything for themselves and not take anyone word for it despite how many say it to know what works and what doesn't he/she must have a very slow learning curve...
   / UTV's and ATV's general discussion. #495
“However I will challenge any who makes unfounded claims such as, "Eggs are yucky" without any further details such as, what kind of egg and how was it prepared?”
I hear that there are some new “fact checker” positions that may have just became available. Maybe this could serve as your resume?
As the Beatles sang “Let it go….”
Anyway back to the Q. 5hp motor, can skid about a 3kLb log. The log underneath generates the traction via weight transfer. 72:1 reduction. 4wd and 4 wheel steer via all belts and cables. Also has plow and 3 pt hitch
Are both your coots 4ws? I hear they are otherwise slow to turn?
   / UTV's and ATV's general discussion. #496
My first one was a 2 wheel steering, but I had it converted to a 4WS. (A guy in Maine who had done the conversion on his own Coot used mine as the vehicle to develop a kit with instructions for the conversion. I later retrofitted a 16 HP Briggs Vanguard V-twin engine in place of the Tecumseh, which had become unreliable.)
My second Coot was 4WS when I bought it, and had already been converted to an 18 HP Vanguard engine.
All Coots are full-time 4WD. They have no differentials: each axle is driven by a worm gear set up, so all 4 wheels turn at exactly the same speed all the time. That combined with a smooth belly with 12" of ground clearance means they rarely got stuck (even with the original 8.85-15 NDT military jeep type tires - which I think frankly suck for traction.) About the only thing that stops it is getting high-centered or sinking into mud so deep the wheels have no traction. When high centered, it's usually easy to fix: shift the weight so at lest one wheel has traction, and the smooth belly will usually slide off the obstruction. Since the front and rear tubs are articulated, the body can pivot, making it easy to keep all four wheels on the ground in most situations. This picture gives you an idea of the articulation (the Coot has since had a roll bar added. It still needs a new paint job - don't know if I'll ever get around to that. This is my "work-in-the-woods" Coot. The new tires I had just put on just prior to this picture are definitely overkill.)
The original 2WS Coots had a huge turning radius. With no differentials, and all wheels turning exactly the same it tended to scrub in the turns and just want to plow ahead. People used to joke about needing an acre of land to turn around, or needing to make 14-point turns to turn around on their trails. A few years into the production run, Coot started offering a 4WS option. It definitely improved the cornering, and Coots with that option fetch a higher price on the market today. They are still not as easily maneuverable as a modern ATV, but they will go places most ATVs couldn't come close to (a tracked ATV might go most places, but the Coot loses them when you drive into the pond and float across.)
   / UTV's and ATV's general discussion. #497
My Tuatara beats my previous Yamaha Rhino 660 every way you look at it.
But they are not silent, just very much quieter. You can hold a conversation at any speed.
Very expensive, too.
And, yes, 50 mile (very short) range. And max 25 mph.
Fine for me in Southern California. I never go over 12 miles in a day.
sweet trailer
   / UTV's and ATV's general discussion. #498
sweet trailer
That is a solid-looking trailer. No info about it on their website.
   / UTV's and ATV's general discussion. #500
Post 462 says nothing like your interpretation.
You claimed specific cold temperature range losses with no citation of sources, or even knowing what battery was in use. And without citing temperatures.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Deere 310L (A53317)
Deere 310L (A53317)
1990 INTERNATIONAL 4700 (A58214)
1990 INTERNATIONAL...
2014 AMERITRAIL TUGGER TRAILER (A58216)
2014 AMERITRAIL...
2020 Hino 195 20ft. Electric Box Truck (A56858)
2020 Hino 195...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
