Utv stalling
/ Utv stalling #1
Mfrick01
Kubota 2800
I have a bulldog utv with a Suburu (Robin) eh65 engine. When going over fairly rough cattle guards the engine stalls. Had to sit for 5 minutes or so before it would restart. Also had the problem on a steep incline. Any ideas what's causing this problem?
/ Utv stalling
If it's carbureted, the float level is too low and it's being starved for fuel (provided it's a gas motor).
It is carbureted. Can the float level be adjusted?
/ Utv stalling #4
Take off the bowl and have a look. Usually you can bend the float tab to adjust the fuel level. Fuel level needs to be at the split between the carb body and the top of the float bowl.
/ Utv stalling
Thanks that is helpful.
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2017 FREIGHTLINER...
2005 CAT 140H MOTOR GRADER (A67714)
2005 CAT 140H...
220 VOLT 6IN SUBMERSIBLE PUMP (A67714)
220 VOLT 6IN...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A65054)
(INOP) 2013 MACK...
2018 CAT D6TXL DOZER (A67714)
2018 CAT D6TXL...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
